New users[/u
Curious Issue sysvinit systemd boot [SOLVED]
Re: Curious Issue sysvinit systemd boot
#11
Post by timkb4cq » Wed Jul 04, 2018 7:02 pm
That could be a bad SATA cable, but I assume you've tried another when you switched drives.
It looks to me like a failing PSU, or failing regulators on the motherboard.
Richard
#12
Post by Richard » Wed Jul 04, 2018 7:06 pm
That is sad.
My condolences.
Best wishes for a speedy recovery.
Laptop: MX18.1: Thinkpad T430: Dual Core, Intel i5-3320M, Ivy Bridge, 8GB RAM, 4.19.0-1-amd64, 119GB SSD 840PRO, Intel Graphics-Audio-Network
Netbook: MX18.1: AsusTek EeePC 1005HA: Intel Dual Core Atom N270, 1GB RAM, 4.19.0-1-686, 150GB HDD
#13
Post by richb » Wed Jul 04, 2018 8:49 pm
All three SSD's are permanently installed with their own cables. Looks like I go searching for a new motherboard, maybe start with the PSU.
Rich
SSD Production: MX 18.1
#14
Post by timkb4cq » Wed Jul 04, 2018 9:14 pm
PSU is more likely. Failing regulators, unless they have just let out the magic smoke, would likely have caused issues with high CPU loads or random usb port problems before getting to this point.
handy
#15
Post by handy » Wed Jul 04, 2018 10:21 pm
@rickb, I'd turn off acpi just to see what happens.
My notebook has a bug in the BIOS. It has taken me sooooo long to realise that this is the case. It has always needed a second (& always successful) attempt to start win7. OpenBSD & Void had no problem, but the 3 Debian based (systemd free) distros do. They too need to be rebooted due to a very early kernel panic (mentions acpi too from memory - not that I think you have the same problem as mine rickb).
Anyway, on doing a little research, I found that it is known that this BIOS has a bug - all this time I had been just putting it down to the xxxxxxx OS's that MS builds (& I consider win7 to be the best of them). I have had to reinstall win7 once, fairly recently, & the behavior (bug) remained - I was hoping that I'd get rid of corruption or whatever had been causing the problem, no such luck. This was of course prior to my realising it was a BIOS bug.
I lived with this bug for years, (I just treat it the same as arthritis...) so I'll see how long it takes me to get my act together & flash the BIOS with an upgrade...
Clevo N'book (2014): P150SM-A
CPU: i7-4810MQ (Haswell) Speed: 2800/3800 MHz
RAM: 16 GiB 1600 MHz DDR3
GPU-1: i915
GPU-2: NVIDIA GK104M [GeForce GTX 880M] vRAM: 8GB 2500 Mhz DDR5
Storage: TOSHIBA 931.51 GiB. HGST 931.51 GiB. Crucial 223.57 GiB (M.2 SSD)
HessenZone
#16
Post by HessenZone » Thu Jul 05, 2018 2:17 am
Looks like potentially a hard disk related error to me ...
https://ubuntuforums.org/showthread.php?t=2272486
More useful info. from Fedora forum ...
https://forums.fedoraforum.org/showthre ... re-problem
Last but certainly not least ...
https://superuser.com/questions/1166750 ... d-shutdown
MX Linux Rocks, in America, in Europa, in Australien, einfach ÜBERALL. :linuxlove:
#17
Post by richb » Thu Jul 05, 2018 5:33 am
I have noticed a clicking every second or so as the error block repeats. One would think HD but I have SSD's.
Doubt that all 3 SSD's went bad at the same time.
EDIT: Just recalled there is an HD in a caddy that I do not boot from. and rarely use. I removed it and the problem is resolved. Thanks for all the comments.
Rich
oops
#18
Post by oops » Thu Jul 05, 2018 7:10 am
Unbelievable .. So it was a Darwin issue, ssds do not like to share the same space with hdds ;)
#19
Post by richb » Thu Jul 05, 2018 7:20 am
Evolution. They coexisted for three years and then came to blows. Actually I just think the HD failed. Not sure why I rarely used it. and never boot from it .But I suppose being in the computer it still wound up on boot.
Rich
Re: Curious Issue sysvinit systemd boot [SOLVED]
#20
Post by timkb4cq » Thu Jul 05, 2018 8:20 am
The system can't tell whether that drive is a boot drive or not until it can iterate it. Usually that won't make a boot fail, just delay it for a minute or two, but drive failures can have odd symptoms.
Return to “MX Help”
