-- MX-18.2 Point Release release info here
Vivaldi & H.264/MP4 (MP3 too I think) & libffmpeg.so
Gerson
Re: Vivaldi & H.264/MP4 (MP3 too I think) & libffmpeg.so
#31
Post by Gerson » Thu Oct 11, 2018 6:29 am
Today Opera was updated to version: 56.0.3051.43 and again it does not play the videos, so with each update you have to use this command again in the terminal:
sudo -v; curl -Lr1078- vvld.in/lm64 | sudo tar xJ -C / --wildcards \*libffmpeg\.so --xform 's,.*/,usr/lib/x86_64-linux-gnu/opera/,'
I already ran it and now Opera plays videos normally. You should think of a scrip attached to the update that does it automatically so you do not have to do it manually. Sometimes he forgets.
handy
#32
Post by handy » Thu Oct 11, 2018 7:53 am
@Gerson, there isn't somewhere else in the system where the libffmpeg.so file can be put that Opera will accept?
Somewhere that won't be overwritten by Opera updates. If no one here knows of a path, perhaps an email, or post in the Opera forum would get an answer from one of the Opera devs.
Clevo N'book (2014): P150SM-A
CPU: i7-4810MQ (Haswell) Speed: 2800/3800 MHz
RAM: 16 GiB 1600 MHz DDR3
GPU-1: i915
GPU-2: NVIDIA GK104M [GeForce GTX 880M] vRAM: 8GB 2500 Mhz DDR5
Storage: TOSHIBA 931.51 GiB. HGST 931.51 GiB. Crucial 223.57 GiB (M.2 SSD)
#33
Post by fehlix » Thu Oct 11, 2018 9:24 am
Running this for opera:
sudo -v; curl -Lr1078- vvld.in/lm64 | sudo tar xJ -C / --wildcards \*libffmpeg\.so --xform 's,.*/,usr/lib/x86_64-linux-gnu/opera/lib_extra/,'
will save within addtional lib_extra folder, which will not be overwritten by an update according to Opera's ffmpeg search-path defined here:
/usr/lib/x86_64-linux-gnu/opera/resources/ffmpeg_preload_config.json:
  "lib_extra/libffmpeg.so",
  "../../../../chromium-ffmpeg/libffmpeg.so",
  "/usr/lib/chromium-browser/libffmpeg.so",
  "/usr/lib/chromium-browser/libs/libffmpeg.so"
handy
#34
Post by handy » Thu Oct 11, 2018 8:31 pm
Thanks fehlix, that should do it for him & the other Opera users. ;)
GPU-1: i915
colin_b
#35
Post by colin_b » Sun Oct 14, 2018 10:05 pm
I am just wondering if the following info from this thread could be used in a sticky post that resides at the top of the software board. This would allow people to easily find the info when installing / updating browsers.
# Vivaldi 64 bit
sudo -v; curl -Lr1078- vvld.in/lm64 | sudo tar xJ -C / --wildcards \*libffmpeg\.so --xform 's,.*/,opt/vivaldi/lib/,'
# Opera 64 bit
# Slimjet 64 bit
sudo -v; curl -Lr1078- vvld.in/lm64 | sudo tar xJ -C / --wildcards \*libffmpeg\.so --xform 's,.*/,opt/slimjet/,'
#36
Post by fehlix » Mon Oct 15, 2018 1:17 pm
As I got today an update for vivaldi I checked again to have ffmpeg survive the update
Here for both opera and vivalid to get ffmepeg into the right folder, which will not be overwritten during an update or reinstall:
# Vivaldi 64 bit - survived reinstall or update
sudo -v; curl -Lr1078- vvld.in/lm64 | sudo tar xJ -C / --wildcards \*libffmpeg\.so --xform 's,.*/,opt/vivaldi/,'
# Opera 64 bit - survives reinstall or update
sudo -v; curl -Lr1078- vvld.in/lm64 | sudo tar xJ -C / --wildcards \*libffmpeg\.so --xform 's,.*/,usr/lib/x86_64-linux-gnu/opera/opera/lib_extra/,'
:puppy:
#37
Post by Jerry3904 » Mon Oct 15, 2018 1:26 pm
# Vivaldi 64 bit
# Opera 64 bit
# Slimjet 64 bit
We can put it into Tips & Tricks.
Gerson
#38
Post by Gerson » Thu Oct 18, 2018 8:04 am
Today with the new update of Opera this command no longer works, with the previous updates I had no problem.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:01 --:--:--     0xz: (stdin): File format not recognized
tar: Child died with signal 13
tar: Error is not recoverable: exiting now
  3 1077k    3 38606    0     0  15454      0  0:01:11  0:00:02  0:01:09 42895
curl: (23) Failed writing body (2162 != 8000)
Gerson
#39
Post by Gerson » Thu Oct 18, 2018 8:50 am
In replacement of Opera install Chromium and have the same problem, does not play videos from the facebook page. Youtube and other pages yes.
#40
Post by fehlix » Thu Oct 18, 2018 9:34 am
Try those:
Vivaldi 64 bit terminal command:
sudo -v; curl -L vvld.in/lm64 |tail -c+1079 | sudo tar xJ -C / --wildcards \*libffmpeg\.so --xform 's,.*/,opt/vivaldi/,'
Opera 64 bit terminal command:
sudo -v; curl -L vvld.in/lm64 |tail -c+1079 | sudo tar xJ -C / --wildcards \*libffmpeg\.so --xform  's,.*/,usr/lib/x86_64-linux-gnu/opera/lib_extra/,'
Slimjet 64 bit terminal command:
sudo -v; curl -L vvld.in/lm64 |tail -c+1079 | sudo tar xJ -C / --wildcards \*libffmpeg\.so --xform 's,.*/,opt/slimjet/,'
