-- Change in MX sources
-- antiX-17 release info here
Can't mount Anti-X partition
Re: Can't mount Anti-X partition
#21 Post by anticapitalista » Mon May 28, 2018 4:21 pm
What exactly did you add.
#22 Post by anticapitalista » Mon May 28, 2018 4:23 pm
oliverjames wrote:
Mon May 28, 2018 4:20 pm
But the question remains, why does AntiX prevent Puppy linux from mounting its partition
Either it is because, as I mentioned before, sda3 needs a fs check and the one on Puppy is too old or Puppy has failed to add antiX partition to /etc/fstab
oliverjames
#23 Post by oliverjames » Mon May 28, 2018 4:32 pm
Yes, could be that, I'll check. Mint will open the partition so the problem appears to be with Puppy.
skidoo
#24 Post by skidoo » Mon May 28, 2018 6:16 pm
Right, it's not a matter of antiX allowing or disallowing. Whatever you started with (i had formed the impression it was some puppy distro), it installed an older version of grub4dos and/or e2fsprogs which cannot handle the metadata present on partitions which have been created via use of the newer e2fsprogs version. antiX uses the newer version, and your older version doesn't recognize, doesn't know how to handle it. The error message literally tells you that "a newer version of e2fsprogs" is required.
oliverjames
#25 Post by oliverjames » Tue May 29, 2018 2:16 am
Yes, during the AntiX install I let it reformat the Ext4 partition (originally created with Puppy 5.7.1).
Return to “Installation”
