[SOLVED]-Syntax error puzzling me
Here you can exchange scripts that you created or have permission to share with other users.
greywolf
Post by greywolf » Mon Dec 11, 2017 11:18 pm
I am sure there is a very simple explanantion to this problem that is just eluding my weary mind at present? This line in a bash script is not parsing - I think I may have the right bracket in the wrong place? The error message is "couln't parse this test expression".
I would appreciate it if anyone could offer a solution to the syntax:
if [ 0 -lt ${size} 2>> ${Trash} ] ; then
cheers,
greywolf.
It is about the Dragons - it was always about the Dragons!
Re: Syntax error puzzling me
Post by Adrian » Tue Dec 12, 2017 12:59 am
I think you left a blank between the redirection and ${Trash} you should write 2>>${Trash}
However I don't see the point of redirecting the stderr, there's no stderr for a comparison as far as I know, you should probably just use:
 if [ 0 -lt ${size} ] ; then
greywolf
Post by greywolf » Tue Dec 12, 2017 7:34 am
Adrian wrote:I think you left a blank between the redirection and ${Trash} you should write 2>>${Trash}
Thanks, Adrian. You were spot on. I found my old bash scripting guide which confirms same.
cheers,
greywolf.
Return to “Scripts”
