-- Change in MX sources
-- antiX-17 release info here
easy string replacement
Here you can exchange scripts that you created or have permission to share with other users.
#1 Post by Jerry3904 » Wed Nov 22, 2017 9:06 am
I needed to change one string in all the conkies, and didn't want to open the scripts one at a time. Googled the problem as "bash replace string many files," and came upon a description on how to use the Debian package rpl.
Installed that, opened a terminal in ~/.conky, and ran this after reading the man page:
rpl -R "override_utf8_locale no" "override_utf8_locale yes" MX-*
--the -R tells the program to run recursively so it will cover all subfolders
--I had to use quotes around the string I wanted to replace (I read) because it contained a space
--All our conkies start with the same prefix (after I made a few changes...), so I could use MX-* to include them.
That appears to have worked just fine, and is much easier for me than figuring out the syntax of sed, the command that is usually recommended.
cyrilus31
Re: easy string replacement
#2 Post by cyrilus31 » Wed Nov 22, 2017 9:32 am
It's great that you succeded Jerry :number1:
How many conky themes do you intend to provide out of the box?
#3 Post by Jerry3904 » Wed Nov 22, 2017 9:52 am
Just trying now to correct the B2 collection, and will probably eliminate a few for Final.
The goal was to set up conky out of the box, develop a tool to make modifications easier, and to provide decent documentation. That has been mostly done now.
#4 Post by Stevo » Wed Nov 22, 2017 4:15 pm
Re: rpl viewtopic.php?f=86&t=43063&p=424292&hilit=rpl#p424292 :happy:
Yes, it is quite useful and powerful!
#5 Post by Jerry3904 » Wed Nov 22, 2017 5:08 pm
Oh sorry, that message was buried in a thread and I never saw it.
Return to “Scripts”
