-- Change in MX sources
-- antiX-17 release info here
Help Request for odd Bluetooth behavior
Help on MX KDE Re-spins
rover
#1 Post by rover » Sun Nov 19, 2017 7:07 am
I 'm attempting to install MX-KDE , on a Lenovo G50-45 ,and i'm experiencing an odd bluetooth behavior. I want to make clear that this happens not just on MX-KDE but on standard MX 64 bit as well , so i must assume that this has to do with the particular machine.
Both Blueman and Bluedevil show bluetooth as active but no matter what i've tried i cannot make the device discoverable .
If it is any help lsusb output is
Bus 004 Device 004: ID 0bda:b728 Realtek Semiconductor Corp.
Bus 004 Device 003: ID 0bda:579a Realtek Semiconductor Corp.
Bus 004 Device 002: ID 0438:7900 Advanced Micro Devices, Inc.
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 002: ID 0438:7900 Advanced Micro Devices, Inc.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
rfkill list output is
$ rfkill list
0: ideapad_wlan: Wireless LAN
        Soft blocked: no
        Hard blocked: no
1: ideapad_bluetooth: Bluetooth
        Soft blocked: no
        Hard blocked: no
2: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
3: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
inxi -F output is
System:    Host: leon Kernel: 4.4.0-0.bpo.1-amd64 x86_64 bits: 64
           Desktop: KDE Plasma 4.14.2 Distro: MX-15_x64 Fusion 24 December 2015
Machine:   Device: laptop System: LENOVO product: 80E3 v: Lenovo G50-45 serial: N/A
           Mobo: LENOVO model: Lancer 5B2 serial: N/A
           UEFI [Legacy]: LENOVO v: A2CN24WW(V1.06) date: 07/09/2014
Battery    BAT1: charge: 27.7 Wh 100.1% condition: 27.7/31.7 Wh (87%)
CPU:       Dual core AMD E1-6010 APU with AMD Radeon R2 Graphics (-MCP-)
           cache: 1024 KB
           clock speeds: max: 1350 MHz 1: 1200 MHz 2: 1350 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R2 Graphics]
           Display Server: X.Org 1.16.4
           drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
           Resolution: 1366x768@60.00hz
           OpenGL: renderer: Gallium 0.4 on AMD MULLINS
           version: 3.3 Mesa 10.3.2
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
           driver: snd_hda_intel
           Card-2 Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio
           Sound: Advanced Linux Sound Architecture v: k4.4.0-0.bpo.1-amd64
Network:   Card-1: Realtek RTL8723BE PCIe Wireless Network Adapter
           driver: rtl8723be
           IF: wlan0 state: up mac: ec:0e:c4:61:c5:7d
           Card-2: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169
           IF: eth0 state: down mac: 28:d2:44:d6:5c:6e
Drives:    HDD Total Size: 1000.2GB (0.9% used)
           ID-1: /dev/sda model: ST1000LM024_HN size: 1000.2GB
Partition: ID-1: / size: 915G used: 6.2G (1%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 2.17GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 44.8C mobo: N/A gpu: 45.0
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 173 Uptime: 2:22 Memory: 1151.0/3416.7MB
           Client: Shell (bash) inxi: 2.3.43
I hope these command results help , and provide a solution
Thank you in advance
Best Regards
asinoro
Re: Help Request for odd Bluetooth behavior
#2 Post by asinoro » Sun Nov 19, 2017 8:02 am
rover wrote:I 'm attempting to install MX-KDE , on a Lenovo G50-45 ,and i'm experiencing an odd bluetooth behavior. I want to make clear that this happens not just on MX-KDE but on standard MX 64 bit as well , so i must assume that this has to do with the particular machine.
$ rfkill list
        Soft blocked: no
        Hard blocked: no
        Soft blocked: no
        Hard blocked: no
        Soft blocked: no
        Hard blocked: no
3: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
inxi -F output is
           cache: 1024 KB
           driver: rtl8723be
           driver: r8169
Best Regards
Where you found this kernel 4.4.0-0.bpo.1-amd64?
If your case is solved edit [Solved] to your initial post title to help other users.
Don’t forget to Backup your system
Fix your Grub
#3 Post by Jerry3904 » Sun Nov 19, 2017 8:21 am
That's a 2-yr old OS, a lot behind where bluetooth apps are now. You might try the MX-17 Beta 1 and see if your results are any different.
rover
Re: Help Request for odd Bluetooth behavior (solved)
#4 Post by rover » Sun Nov 19, 2017 9:54 am
@asinoro the kernel is what the iso came with, its the MX-KDE respin iso.
@jerry 3904 thank you for the suggestion i guess i 'll redo the proccess from scratch .
Should anything come up , i 'll let you know in a new topic .
Best Regards
Return to “MX KDE”
