The MX-17 conkies
Re: The MX-17 conkies
#141
Post by Jerry3904 » Thu Nov 30, 2017 6:06 pm
I should add that I have no idea whether a date like 11/30/17 will localize at all, but was trying got a Conky with minimal translation needs.
#142
Post by richb » Fri Dec 01, 2017 6:34 am
They look fine to me. One anomaly. With the default Gotham if I changed the day to short using MX Conky the bottom half of the conky was cut off. I corrected it by reducing the window height. Why that works is an unknown to me. Same result on both my desktop and laptop.
Rich
SSD Production: MX 18.1
#143
Post by Jerry3904 » Fri Dec 01, 2017 6:35 am
Thanks. That stuff is hard to figure out exactly. What width did you reduce it to?
#144
Post by richb » Fri Dec 01, 2017 6:37 am
Jerry3904 wrote:Thanks. That stuff is hard to figure out exactly. What width did you reduce it to?
it was changing the height, not width. Corrected my post. Too early in the AM.
Rich
#145
Post by Jerry3904 » Fri Dec 01, 2017 6:38 am
So...what height did you reduce it too?
#146
Post by richb » Fri Dec 01, 2017 6:40 am
minimum_size 500 250
Rich
#147
Post by Jerry3904 » Fri Dec 01, 2017 10:40 am
That's what I have already in the new default Gotham: are you sure you opened the one in the Default folder?
#148
Post by richb » Fri Dec 01, 2017 10:48 am
I just installed a fresh b3. It is in the default dirctory. That line with no changes is
minimum_size 0 0 and cutoff occurs
Changing it to
minimum_size 500 250 corrects.
Rich
#149
Post by Jerry3904 » Fri Dec 01, 2017 11:41 am
Aha! But you're supposed to be testing the conkies in that file I linked to above, where that correction has already been made. I'm all set now, thanks.
#150
Post by richb » Fri Dec 01, 2017 12:10 pm
Ok, so am i. Two machines and multiple installs has me gaga. I think they are in pretty good shape as they are.
Rich
Return to “Desktop Environment”
