MX-16 Screenshots
Show us how you are setting up MX-14!
Re: MX-16 Screenshots
#191
Post by Jerry3904 » Wed May 16, 2018 2:45 pm
Very handsome, and witty too.
MX<3
#192
Post by MX<3 » Sat May 19, 2018 8:35 pm
asqwerth wrote:
Wed May 16, 2018 1:30 pm
Latest screenshot from my test MX15 (Jessie) partition that I'm still using.
The Lollypop media player running is the flatpak version since Jessie's gtk+ version is too old to run Lollypop otherwise.
It works but not for themeing. No matter what gtk theme you apply, flatpak Lollypop will just show up in standard Adwaita theme....
I like that wallpaper. It's really cool.
My Computer
Gigabyte B360M-DS3H Motherboard
Intel Core i3-8100 3.6GHz Quad Core CPU
2x 4GB DDR4 2400 Memory Modules
NVidia GeForce GTX 1050 Ti Grfx Card
HDD x2 @ 1TB
#193
Post by asqwerth » Sun May 20, 2018 5:50 am
Thanks. Saw it in the monthly screenshot thread at Manjaro forum and a link was given, which I now can't find. I can't even remember which folder on my hard drive I saved the wallpaper to, so I did a reverse search of my own screenshot above and got a few hits for the original pic.
https://www.tineye.com/search/99962c161 ... b585a351c/
You can download from the first search result.
Looks like it was a pic posted to wallhaven at one point.
Artim
#194
Post by Artim » Sun May 20, 2018 12:07 pm
Playing around with MX-Clocky and Neofetch for the first time. Screenshot is in this blog post. Loving my MX!
rich
#195
Post by rich » Sun May 20, 2018 12:33 pm
Interesting panel configuration, dock at bottom with system tray on top
And I loved it cuz
It was all about me.
#196
Post by asqwerth » Sat Jun 30, 2018 1:37 pm
While waiting for the Uru v Por match, here's a screenshot with wallpaper by Antechdesigns and the HTC Android-esque conky from the instructions posted here:
https://forum.mxlinux.org/viewtopic.php ... 20#p444820
by @male.
https://imgur.com/WDQsFff
#197
Post by asqwerth » Sun Jul 01, 2018 1:47 pm
Have now got the bigger weather conky from @male ( https://forum.mxlinux.org/viewtopic.php ... 10#p445610 ) set up, plus I added a system-info conky below to complement it.
Bottom conky uses the new syntax, slightly modified from something off a live iso of Archmerge (now called arcolinux). Had to tweak the "number of updates" text to work with a Debian-based OS, and also adjusted the transparency/ARGB settings to work properly with Compiz.
Next step is to see if I am able to tweak and change these weather conkies from @male to display only the information I want, or maybe lay out the conky differently.
https://imgur.com/LjhhB6N
male
#198
Post by male » Sun Jul 01, 2018 2:39 pm
@asqwerth
splendid work! :number1:
asqwerth wrote:by @male
Male is the capital of the Maldives and its wonderful people. :happy:
I'd like to give you this script. The how-to is written at the beginning (you will understand it). It makes backgrounds ;) for your Conky's in a simple way. I got it from a good friend
draw_bg_convert.sh
#!/bin/bash
#inspiration: jpdipsy help-scripting: daniel38100 idea: ragamatrix from forum ubuntu-fr
#Examples how-to
#syntaxe calling cartouche BG :
#~/bin/draw_bg_convert.sh crea_cart "BG" "715x105" "cadre" "red" "0" "blue" "5"
#crea_cart "BG" "715x102" "cadre" "#00000000" "0" "#00000060" "5" #BG without square
#crea_cart "BG" "715x105" "cadre" "silver" "0" "#00000040" "5" #BG with square
#			^name.png  ^size(x-y) ^frame   |    |	|		|		|
#									  color frame   |		|
#											thickness frame |
#													color background
#															corner radius
#You can change the reptemp path by your /pathes/choices you want
if [ ! -z $9 ];then
    reptemp="$9"
elif [ -z $4 ];then
    reptemp=/tmp
elif [ $4 != "cadre" ];then
    reptemp=$4
else
    reptemp=/tmp
fi
echo $reptemp > ~/test.log
case "$1" in
    crea_cart )
        nom="$reptemp/$2.png" ;export image_"$2"="$nom" ;taille="$3";cadre="$4";couleur="$5";bordure="$6";couleurfond="$7";arrondi="$8"
        if [[ $4 = "cadre" ]];then
            # rectangle 1px de moins sur la taille
            L=$(echo $taille|cut -d x -f1);L=$((L - 1))
            H=$(echo $taille|cut -d x -f2);H=$((H - 1))
            convert -size "$taille" xc:none  -fill "$couleurfond" -strokewidth "$bordure" -stroke "$couleur" -draw "roundrectangle 1,1 $L,$H $arrondi,$arrondi" "$nom"
        else
            convert  -size "$taille" xc:none "$nom"
        fi
esac
exit
k_sz
#199
Post by k_sz » Fri Jul 20, 2018 4:18 am
*wrong topic, sorry*
> Desktop : AMD 64 bits (unknowned monocore model :P looking for an AM2+ 4cores Phenom) | RAM 4Go DDR2 | MX17.1@daily updates
> Laptop : Work In Progress, Celeron monocore | DDR2 | Probably antiX ^^
#200
Post by asqwerth » Fri Jul 20, 2018 6:03 am
draw_bg_convert.sh
#!/bin/bash
#Examples how-to
#									  color frame   |		|
#											thickness frame |
#													color background
#															corner radius
if [ ! -z $9 ];then
    reptemp="$9"
elif [ -z $4 ];then
    reptemp=/tmp
    reptemp=$4
else
    reptemp=/tmp
fi
case "$1" in
    crea_cart )
        else
        fi
esac
exit
Thanks, @male. I don't know when I'll get down to testing this script, but some preliminary questions:
1. may I assume that it is meant to be called from within a conky config file using some or all of the example commands in the commented-out section?
2. a lot of the script appears to be in French. I'll need to convert them all to English, right?
Return to “Themes and Screenshots”
