-- Change in MX sources
-- antiX-17 release info here
Packages being worked on by the Repo Team
Discussion about the MEPIS Community's Repo.
mmikeinsantarosa
Re: Packages being worked on by the Repo Team
#1001 Post by mmikeinsantarosa » Tue Jun 26, 2018 9:49 pm
Nope. I ll get it on the next release. Tx for the reminder.
LT: MX17.1 Quad Core model: Intel Core i7-6820HQ Kernel: 4.16.0-12.1-liquorix-amd64 (64 bit)
KoO
#1002 Post by KoO » Wed Jun 27, 2018 2:20 am
turtlebay777 wrote:
Tue Jun 12, 2018 5:05 pm
Hope this is right forum!
Is it possible to add Waterfox to the repos?
If you want Waterfox now just use this.
WATERFOX MX17
Adding repository
Run these commands to add this repostory to your APT sources list:
echo 'deb https://dl.bintray.com/hawkeye116477/waterfox-deb release main' | sudo tee /etc/apt/sources.list.d/waterfox.list
And the public GPG key:
curl https://bintray.com/user/downloadSubjec ... keye116477 | sudo apt-key add -
You can download and install the packages after you update the APT package index:
sudo apt-get update { I just us [sudo apt update] no need for the (get) any more..
And it will keep Waterfox updated as well.
Da Main Box .. Antix 17.1 (4.17.4) i3 Intel Xeon E3-1241 v3 , 16gb HyperX , Samsung EVO M2 250 GB , Samsung EVO SSD 500 GB , GTX 970
Lappy .. Lenovo T430 AntiX17.1 (4.17.4) i3 ,blowdozs8.1 , i5 +4000 , 8gb , Samsung EVO 860 250 GB , 1TB HGST
#1003 Post by Stevo » Wed Jun 27, 2018 1:55 pm
If you've never done that before, the two files that need changing are debian/control and debian/compat.
#1004 Post by Stevo » Wed Jun 27, 2018 4:47 pm
Working on the new Krita 4.1.0. It hasn't made it to Sid yet, but I looked at the Debian maintainer's changelog in the VCS git repo for 4.1.0 to make sure mine matches up, such as adding libheif-dev for the new HEIF plugin. (HEIF=new iPhone image format)
Edit: Despite what Krita's 4.1.0 CmakeLists.txt file said, the libheif-dev 1.1.0 version we had for GIMP 2.10 was not new enough and the build failed. Backporting and building against libheif 1.3.2 was successful. Installed it and it works, so am uploading now.
#1005 Post by timkb4cq » Wed Jun 27, 2018 8:03 pm
Otter-browser for MX-17 test
mmikeinsantarosa
#1006 Post by mmikeinsantarosa » Thu Jun 28, 2018 7:39 am
But of course, just like a roll cast.
#1007 Post by Stevo » Sat Jun 30, 2018 2:56 pm
Uploading last Liquorix 4.16-11 kernel and new Liquorix 4.17-1 (based on 4.17.3 vanilla source) now. I tested the 4.17 in a Virtual Box MX guest, and the guest drivers still work (video, shared folders), but I don't know yet if that's using the drivers that are now built with the kernel instead of our packages.
#1008 Post by Stevo » Sat Jun 30, 2018 4:36 pm
MuseScore 2.3 for MX 17. MX 15/16 is left out, since it requires a newer Qt 5 than can be provided, but the AppImage might work there.
#1009 Post by Stevo » Tue Jul 03, 2018 3:05 pm
Debian packaged kernel 4.17.3 for Sid, so I'll try backporting it. With this new version, they enabled the Virtual Box guest driver support built into the kernel, as well as the internal drivers to support Anbox (virtual Android machines?)
Openshot-qt video editor 2.4.2 for MX 15/16 and 17 (finished and uploading)
mmikeinsantarosa
#1010 Post by mmikeinsantarosa » Tue Jul 03, 2018 7:05 pm
tales-of-majeyal-1.5.10.
weird, this one wouldn't go using pbuilder but had no problem building on a vm.
- mike
Return to “CR Discussion”
