-- Change in MX sources
-- antiX-17 release info here
MX is slow after lqast update
jerry525
#1 Post by jerry525 » Tue Sep 30, 2014 3:02 am
Hello, I have two computers both performing slowly after the last update.
CPU is cycling & everything is jittery (not smooth). Here are my specs:
Processor : 2x Intel(R) Atom(TM) CPU N270 @ 1.60GHz
Memory : 2063MB (380MB used)
Resolution : 1024x600 pixels
OpenGL Renderer : Mesa DRI Intel(R) 945GME x86/MMX/SSE2
HTOP shows it's the usr/bin/x..... that is consuming the cpu
Can anyone help please?
joany
Re: MX is slow after lqast update
#2 Post by joany » Tue Sep 30, 2014 10:20 am
By "last update" are you referring to the Intel graphics driver package? Also, could you be more specific as to which /usr/bin/x... process is chewing up CPU and how much?
2.4GHz AMD Athlon 4600+
jerry525
#3 Post by jerry525 » Tue Sep 30, 2014 11:58 am
Thanks. Yes it was the graphics drivers.
The process is: usr/bin/x -dpi $DPI :0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
It is consuming 5-12% cpu.
kmathern
#4 Post by kmathern » Tue Sep 30, 2014 12:22 pm
Could you post the output of the following?
inxi -Gxx
Fwiw I get similar cpu usage on my system because it's using "GLX Renderer: Gallium 0.4 on llvmpipe" (software rendering). I have Kabini - Radeon HD 8240 graphics, but they're not supported that well in Wheezy.
jerry525
#5 Post by jerry525 » Tue Sep 30, 2014 1:01 pm
Graphics: Card: Intel Mobile 945GSE Express Integrated Graphics Controller
bus-ID: 00:02.0 chip-ID: 8086:27ae
Display Server: X.Org 1.12.4 drivers: intel (unloaded: fbdev,vesa)
Resolution: 1024x600@60.0hz
GLX Renderer: Mesa DRI Intel 945GME x86/MMX/SSE2
GLX Version: 1.4 Mesa 8.0.5 Direct Rendering: Yes
kmathern
#6 Post by kmathern » Tue Sep 30, 2014 3:28 pm
jerry525 wrote:Graphics: Card: Intel Mobile 945GSE Express Integrated Graphics Controller
That looks right.
lucky9
#7 Post by lucky9 » Tue Sep 30, 2014 3:45 pm
boot into init 3 and run sgfxi as root
you might have to do this twice
--Mark Twain
#8 Post by richb » Tue Sep 30, 2014 4:07 pm
lucky9 wrote:boot into init 3 and run sgfxi as root
Worth a try, but usually does not help much with Intel graphics cards.
Rich
SSD Production: MX 17.1
#9 Post by Adrian » Tue Sep 30, 2014 4:25 pm
Is compositing turned on? You might need to turn it off. From Settings -> Windows Manager Tweaks -> Compositor tab.
#10 Post by Stevo » Tue Sep 30, 2014 5:49 pm
There was an update in wheezy-backports to the Intel driver to
xserver-xorg-video-intel_2.21.15-2~bpo70+1
If you think this upgrade is causing the problem, and you have rebooted and confirm that the problem persists, you can downgrade to the stock Wheezy version in Synaptic (Force Version) of 2:2.19.0-6 to see if that cures it. Make sure to reboot after the downgrade.
Return to “Older Versions”
