MX Package Installer - two options of the same package ?  [Solved]
~FLOW~
#1 Post by ~FLOW~ »
Hello my excelent friends,
From time to time I notice this thing in MXPI, two identical options of the same package, is this normal ?
Is it a bug, or I don't get it ?
MX-23 / KDE Plasma 5.27.5
Kernel: 6.5
Be patient !!
What seams easy for you now, for a newbie might be a monumental helping hand.
An efficient pack will move as fast as the slowest member.
Mauser
Re: MX Package Installer - two options of the same package ?
#2 Post by Mauser »
I just checked on my computer and see that also. Keep in mind that you are in the testing repo which may or may not cause issues when you install anything from it. Perhaps that's why it does that.
#3 Post by dolphin_oracle »
Mauser wrote: Wed Jan 11, 2023 12:18 pm I just checked on my computer and see that also. Keep in mind that you are in the testing repo which may or may not cause issues when you install anything from it. Perhaps that's why it does that.
probably just some sort of text parsing issue
#4 Post by timkb4cq »
Something didn't update correctly since the version should be winehq-staging_8.0-0rc2-0mx21+1 - not rc1.
I would like to know which mirror you have selected for the MX testrepo
~FLOW~
#5 Post by ~FLOW~ »
timkb4cq wrote: Wed Jan 11, 2023 12:28 pm Something didn't update correctly since the version should be winehq-staging_8.0-0rc2-0mx21+1 - not rc1.
System:    Kernel: 5.19.0-2mx-amd64 [5.19.11-1~mx21+1] x86_64 bits: 64 compiler: gcc v: 10.2.1
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.19.0-2mx-amd64
           root=UUID=<filter> ro
           Desktop: KDE Plasma 5.20.5 wm: kwin_x11 vt: 7 dm: SDDM
           Distro: MX-21.2.1_KDE_x64 Wildflower April 9  2022 base: Debian GNU/Linux 11 (bullseye)
Machine:   Type: Portable System: Dell product: Inspiron 3542 v: N/A serial: <filter> Chassis:
           type: 8 serial: <filter>
           Mobo: Dell model: 0926J6 v: A16 serial: <filter> UEFI: Dell v: A16 date: 09/02/2020
Battery:   ID-1: BAT0 charge: 21.3 Wh (100.0%) condition: 21.3/41.4 Wh (51.4%) volts: 16.9
           min: 14.8 model: SANYO DELL 4WY7C45 type: Li-ion serial: <filter> status: Full
           Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
           charge: 55% (should be ignored) rechargeable: yes status: Discharging
           Device-2: hidpp_battery_1 model: Logitech K520 serial: <filter>
           charge: 70% (should be ignored) rechargeable: yes status: Discharging
CPU:       Info: Dual Core model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell
           family: 6 model-id: 45 (69) stepping: 1 microcode: 26 cache: L2: 3 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 13569
           Speed: 1172 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 1172 2: 1140 3: 1070
           4: 1397
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: mmio_stale_data status: Unknown: No mitigations
           Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP:
           conditional, RSB filling, PBRSB-eIBRS: Not affected
Graphics:  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915 v: kernel
           bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
           Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M]
           vendor: Dell driver: N/A alternate: nouveau bus-ID: 08:00.0 chip-ID: 10de:1140
           class-ID: 0302
           Device-3: Suyin Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 2-1.5:5
           chip-ID: 064e:9205 class-ID: 0e02 serial: <filter>
           Display: x11 server: X.Org 1.20.14 compositor: kwin_x11 driver: loaded: modesetting
           unloaded: fbdev,vesa display-ID: :0 screens: 1
           Screen-1: 0 s-res: 1280x720 s-dpi: 96 s-size: 337x190mm (13.3x7.5")
           s-diag: 387mm (15.2")
           Monitor-1: HDMI-1 res: 1280x720 dpi: 203 size: 160x90mm (6.3x3.5") diag: 184mm (7.2")
           OpenGL: renderer: Mesa Intel HD Graphics 4400 (HSW GT2) v: 4.6 Mesa 22.0.5
           compat-v: 3.1 direct render: Yes
Audio:     Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel v: kernel
           bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
           Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel v: kernel
           bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
           Sound Server-1: ALSA v: k5.19.0-2mx-amd64 running: yes
           Sound Server-2: PulseAudio v: 15.0 running: yes
Network:   Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Dell
           driver: ath9k v: kernel modules: wl port: f040 bus-ID: 06:00.0 chip-ID: 168c:0036
           class-ID: 0280
           Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169
           v: kernel port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8136 class-ID: 0200
           Device-3: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153] type: USB
           driver: r8152 bus-ID: 3-1.4:4 chip-ID: 2357:0601 class-ID: 0000 serial: <filter>
           IF: eth1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Qualcomm Atheros AR9462 Bluetooth type: USB driver: btusb v: 0.8
           bus-ID: 2-1.6:8 chip-ID: 0cf3:0036 class-ID: e001
           Report: hciconfig ID: hci0 rfk-id: 2 state: down bt-service: N/A rfk-block:
           hardware: no software: no address: <filter>
           Info: acl-mtu: 1022:8 sco-mtu: 183:5 link-policy: rswitch hold sniff
           link-mode: slave accept
Drives:    Local Storage: total: 2.49 TiB used: 1.57 TiB (63.0%)
           ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-75JC3T0
           size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
           rpm: 5400 serial: <filter> rev: 1A01 scheme: MBR
           ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SHSS37A240G size: 223.57 GiB
           block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
           rev: 001B scheme: GPT
           ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: Expansion size: 1.36 TiB
           block-size: physical: 4096 B logical: 512 B type: N/A serial: <filter> rev: 0502
           scheme: GPT
Partition: ID-1: / raw-size: 215.31 GiB size: 210.87 GiB (97.94%) used: 114.99 GiB (54.5%)
           fs: ext4 dev: /dev/sdb2 maj-min: 8:18
           ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 277 KiB (0.1%) fs: vfat
           dev: /dev/sdb1 maj-min: 8:17
Swap:      Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
           ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb3
           maj-min: 8:19
Sensors:   System Temperatures: cpu: 42.0 C mobo: 42.0 C
           Fan Speeds (RPM): cpu: 0
Repos:     Packages: note: see --pkg apt: 2687 lib: 1558 flatpak: 0
           Active apt repos in: /etc/apt/sources.list.d/brave-browser-release.list
           1: deb [signed-by=/usr/share/keyrings/brave-browser-archive-keyring.gpg arch=amd64] https://brave-browser-apt-release.s3.brave.com/ stable main
           1: deb http://deb.debian.org/debian/ bullseye-updates main contrib non-free
           1: deb http://deb.debian.org/debian/ bullseye main contrib non-free
           2: deb http://security.debian.org/debian-security/ bullseye-security main contrib non-free
           3: deb-src http://deb.debian.org/debian/ bullseye main contrib non-free
           4: deb http://deb.debian.org/debian/ bullseye-backports main contrib non-free
           Active apt repos in: /etc/apt/sources.list.d/dropbox.list
           1: deb [arch=i386,amd64] http://linux.dropbox.com/debian/ sid main
           1: deb http://it.mxrepo.com/mx/repo/ bullseye main non-free
           No active apt repos in: /etc/apt/sources.list.d/nala-sources.list
           Active apt repos in: /etc/apt/sources.list.d/signal-xenial.list
           1: deb [arch=amd64 signed-by=/usr/share/keyrings/signal-desktop-keyring.gpg] https://updates.signal.org/desktop/apt/ xenial main
           Active apt repos in: /etc/apt/sources.list.d/steam.list
           1: deb [arch=amd64,i386] https://repo.steampowered.com/steam/ stable steam
           2: deb-src [arch=amd64,i386] https://repo.steampowered.com/steam/ stable steam
           Active apt repos in: /etc/apt/sources.list.d/volian-archive-scar-unstable.list
           1: deb http://deb.volian.org/volian/ scar main
Info:      Processes: 223 Uptime: 6m wakeups: 11 Memory: 7.68 GiB used: 2.27 GiB (29.5%)
           Init: SysVinit v: 2.96 runlevel: 5 default: 5 tool: systemctl Compilers: gcc: 10.2.1
           alt: 10 Client: shell wrapper v: 5.1.4-release inxi: 3.3.06
Kernel: 6.5
Be patient !!
#6 Post by fehlix »
~FLOW~ wrote: Wed Jan 11, 2023 5:49 am Hello my excelent friends,
What other packages are those and are those only listed as dublicates within the Test-Repo tabe of MXPI?
To check what testrepo may be involved, please post QSI (Quick System Info), b/c testrepo would be taken from the first mx-repo in the list, if not have been kept manually enabled.
+++EDIT+++ OK. thanks for the QSI
~FLOW~
#7 Post by ~FLOW~ »
fehlix wrote: Wed Jan 11, 2023 2:23 pm What other packages are those and are those only listed as dublicates within the Test-Repo tabe of MXPI?
At the moment I can't remember, only that it wasn't wine...
Kernel: 6.5
Be patient !!
#8 Post by timkb4cq »
Thank you. There is a problem with that mirror I had not noticed. Working on it.
#9 Post by fehlix »
OK, the it.mxrepo.con seems to be not updated since end of december:
curl -I http://it.mxrepo.com/mx/repo/dists/bullseye/InRelease
HTTP/1.1 200 OK
Last-Modified: Fri, 30 Dec 2022 00:53:48 GMT
Content-Length: 19886
But even if I enable this repo, I do see two packages not one wine-staging and wine-staging-amd64:
Suggest to switch mx-repo, and check whether you still see two identical packages listed.
May be to trying to reproduce post text out put of
apt policy wine-staging wine-staging-amd64
+++ EDIT +++ Removed "-a" from apt policy ( that the one I use for apt show -a ...)
~FLOW~
#10 Post by ~FLOW~ »
Ok, something happened while I was taking the screenshot.
After the screenshot, I had 3 identical packages
So I restart MX Package Installer and now it shows only one !
$ apt policy wine-staging wine-staging-amd64
wine-staging:
  Installed: 7.15-1mx21+1
  Candidate: 7.15-1mx21+1
  Version table:
 *** 7.15-1mx21+1 100
        100 /var/lib/dpkg/status
     6.22-1mx21+2 500
        500 http://it.mxrepo.com/mx/repo bullseye/main amd64 Packages
wine-staging-amd64:
  Version table:
     6.22-1mx21+2 500
Kernel: 6.5
Be patient !!
