Bitwarden's appimage fails to run
philotux
#1 Post by philotux »
I have wanted to check out how Bitwarden's Linux client works, so I downloaded the appimage. I made it executable but double clicking on it won't get it started. Some Bitwarden processes do show up in the system Monitor but nothing shows up on the desktop.
Running it from a terminal produces the following:
$ ./Bitwarden-1.12.0-x86_64.AppImage
zenity, kdialog, Xdialog missing. Skipping /tmp/.mount_BitwarCgUr6d/AppRun.
A JavaScript error occurred in the main process
Uncaught Exception:
Error: /tmp/.org.chromium.Chromium.zzetGZ: failed to map segment from shared object
    at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:166:20)
    at Object.Module._extensions..node (internal/modules/cjs/loader.js:740:18)
    at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:180:18)
    at Module.load (internal/modules/cjs/loader.js:620:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
    at Function.Module._load (internal/modules/cjs/loader.js:551:3)
    at Module.require (internal/modules/cjs/loader.js:658:17)
    at require (internal/modules/cjs/helpers.js:20:18)
    at Object.<anonymous> (/tmp/.mount_BitwarCgUr6d/resources/app.asar/node_modules/desktop-idle/index.js:1:176)
    at Object.<anonymous> (/tmp/.mount_BitwarCgUr6d/resources/app.asar/node_modules/desktop-idle/index.js:3:3)
I don't know if the problem is at my end or there is something wrong with the appimage.
Appreciate your help.
TIA
Re: Bitwarden's appimage fails to run
#2 Post by Jerry3904 »
Well the segment you quote does say 1) that 3 applications are missing, and 2) there is a seg fault (I guess). So I conclude that the problem is not on your end.
I see there is a flatpak version, you might try that via MX Package Installer
philotux
#3 Post by philotux »
Jerry3904 wrote: Mon Feb 11, 2019 7:50 am Well the segment you quote does say 1) that 3 applications are missing, and 2) there is a seg fault (I guess). So I conclude that the problem is not on your end.
Thank you Jerry3904 for looking into this! Good to know that the problem is not on my end. And thanks for the tip on the flatpak application. I will have a look at it.
xali
#4 Post by xali »
bitwarden appimage runs fine here though...
philotux
#5 Post by philotux »
xali wrote: Mon Feb 11, 2019 8:50 am bitwarden appimage runs fine here though...
Hmm... maybe I should download the image again and see if it runs as it should. If it doesn't, then perhaps the problem is on my end after all.
:confused:
philotux
#6 Post by philotux »
Downloaded the appimage again. Same issue as per my OP. Postponing trying out Bitwarden for the moment.
#7 Post by Jerry3904 »
Did you try the flatpak? I'm interested in seeing whether that works for you.
manyroads
#8 Post by manyroads »
I tried running a set of tests (here and on other distro sites) on appimages. The response was underwhelming; I received one response from the manjaro site. My single respondant indicated that not all appimages work on all platforms. In other words of the appimages that worked for me not all worked for him (one did not).
#9 Post by Jerry3904 »
That's helpful info, thanks. We need to get some user experiences with appimages on MX-18, and that's a good start.
manyroads
#10 Post by manyroads »
Jerry3904 wrote: Tue Feb 12, 2019 12:13 pm That's helpful info, thanks. We need to get some user experiences with appimages on MX-18, and that's a good start.
I have wonderful success with LibreOffice-fresh and also successfully run (albeit much less frequently) Scrivener, Openshot, avidemux, and RawTherapee
