Good Night...
I send the following incident to the forum without doing the homework (search the forum first) and I apologize for it.
After installing the latest updates, Thunar can take 26 seconds to execute, sometimes a second instance is executed a few seconds later.
It does not happen to me with other applications.
Any ideas?
Where do I start to look?
thanks,,,
Dual Core Intel Core i5-7200U (-MT MCP-) speed/min/max: 723/400/3100 MHz
Kernel: 4.15.0-1-amd64 x86_64 RAM: total: 7.68 GiB used: 1.25 GiB Storage: 931.51 GiB (4.4% used)
Desktop: Xfce 4.12.3 tk: Gtk 2.24.31 info: xfce4-panel wm: xfwm4 dm: LightDM 1.18.3
MX-18_x64 Continuum December 15 2017
Slowed System (Thunar)
Re: Slowed System (Thunar)
My system did this for a while (not quite as long as yours, but noticeable), but the problem went away on its own. I never did figure out what was causing it.jsomonte wrote: ↑Mon Jan 28, 2019 8:33 pm Good Night...
Any ideas?
thanks,,,
Exactly, the problem has disappeared by itself, I have Usain Bolt again as an operating system.
Thanks for comment.
Greetings from Madrid.
Thanks for comment.
