[Solved] MX-16, nouveau, and GeForce4, confusion
Hello MX forum! This may be my first post here. But I've lurked here for years and have been active on the antiX forum. This is mostly a question about MX but I also have the same questions with antiX. Here goes ...
I’ve done a lot of reading and testing over the past few days and I’ve learned a lot about the nouveau driver and Xorg and kernels, etc. But I still don’t understand why the nouveau driver does not work for my hardware with the latest versions of antiX and MX. Can someone help me understand what is actually happening behind the scenes that will either allow the nouveau driver to be installed successfully or not even get loaded? I’ve not been able to find a clear write up about how this works and I’ve read most of nouveau.freedesktop.org already.
I have an old HP zv5000 Athlon XP laptop that I have been setting up with MX Linux. I started with MX-16 and it loaded fine and the screen looked good. But when I tried to play YouTube video using SMTube the video was choppy and out of sync. I have experienced this before when I was trying to get antiX-17 working on my old P-III. That machine plays video fine on antiX-16 but not on antiX-17, on the same hardware,
But I was surprised that this HP Athlon XP 3000+ would not be better at playing YouTube than the P-III. This is a P4 class machine and was made for Windows XP and runs at between 800 and 1600 Mhz and has 1280 MB Ram. That is twice the speed of the P-III and more than twice the memory. It also has the next generation of the Nvidia GeForce (the P-III has a GeForce2 NV11, this HP Athlon has a GeForce4 NV17).
I also tried installing antiX-17 on this machine. It installed fine and the screen is fine but the same results with YouTube. Choppy and out of sync.
After some research I found that the nouveau driver was not being loaded. And without the nouveau kernel module loaded Xorg would not work with it’s nouveau driver either. When I looked at the P-III system the nouveau kernel module is loading and Xorg loads it’s nouveau driver and ends up supporting the GeForce2 graphics card. That system was running antiX-16, not 16.1 or 16.2, but plain 16.
I grabbed my USB with Live antiX-16 and installed that on this HP Athlon. But I ended up with the same result. Bad video and no nouveau driver. I looked closer and found I had antiX-16.2 installed. It’s the same kernel and same Xorg but for some reason it did not load the nouveau driver. So I setup another USB with plain antiX-16 and tried that. Viola! antiX-16 loads the nouveau driver and plays YouTube videos in 360p just fine. Not choppy at all. When I look at the logs everything looks good and the GeForce4 graphics is supported. Hmm. Why does it work in antiX-16 but not in antiX-16.2?
I decided to try MX-15. When I loaded the live MX-15 I looked at lsmod, inxi, and Xorg.log and everything looked good with the nouveau drivers. I played some YouTube video with VLC at 360p and it was fine. So, I have MX-15 and antiX-16 playing YouTube video and using the nouveau drivers. But I can’t duplicate this in either MX-16 or antix-16.2, or antiX-17. Why?
My goal was to get this laptop setup with MX Linux so I could replace an older Dell P-III-450 laptop that I use for playing music in my office. I thought I could use at least MX-16, if not MX-17/18. But I had to settle for MX-15 and I’m confused as to why. MX-16 uses an earlier kernel than antiX-16.2 or antiX-17 and uses the same Xorg as antiX-16. I thought that would work out for me, but so far it doesn’t work. Clearly, there is more to this puzzle than the kernel and Xorg version.
I decided to experiment with upgrading MX-15. I was worried that if I ran “dist-upgrade” I would end up with bad video again, thinking that MX-16 gives me bad video and MX-15 gives me good video. I ran into problems updating SMPlayer and SMTube from MX-15 due to some repository issues. I finally figured out that the sources list files needed to be corrected to point to the correct servers. Once I did that I was able to do a full dist-upgrade and I ended up installing the latest SMPLayer and SMTube along with SeaMonkey, Palemoon and Remmina. I tested the video after the upgrades and it played and looked fine. I checked the logs and the nouveau driver was loaded and Xorg was using it.
When I rebooted I had no grub image and the login image was also blank. The desktop wallpaper was also gone. I had experienced this before and was able to find the new paths to the images and edit the startup files. MX did a couple more “dist-upgrades” and I noticed that one of the last upgrades were for the linux-headers files. Again, I was worried that this might kill my video setup and I’d end up with bad video again. But I tested it after it finished and the video is fine. When I rebooted I had MX-16 Metamorphosis as indicated from the Welcome screen. But my video was still good.
So, now I have MX-16 installed, by way of a MX-15 install and a full upgrade. But unlike the direct install of MX-16 from the USB media I now have good video working with the nouveau driver on the GeForce4 graphics hardware.
I learned a lot about installing and updating MX-15 but I am still confused as to why the nouveau driver does not load with MX-16 from the USB media, or on antiX-16.2 or antiX-17. Is it even possible to get the nouveau driver installed on those other versions? Could I do something similar with antiX-17 and start with antiX-16 and then do a full upgrade to antiX-17? Or is there something about those versions that just won’t support this GeForce4 NV17M hardware? And if that is the case then why do I now have a version of MX-16 working on this hardware?
Confused!
Seaken64
Confused!
Seaken64
Re: MX-16, nouveau, and GeForce4, confusion
Here's inxi from the HP Athlon XP:
(This is with antiX-16.2 loaded. But same result with MX-16 from media)
Host: antix16 Kernel: 4.4.10-antix.1-486-smp i686 bits: 32
Desktop: IceWM 1.3.8
Distro: antiX-16.2_386-full Berta Cáceres 15 June 2017
Type: Laptop System: Hewlett-Packard
product: Pavilion zv5200 (PT277UA#ABA) v: F.34 serial: <root required>
Mobo: Compal model: 08A0 v: 32.41 serial: <root required>
BIOS: Hewlett-Packard v: F.34 date: 12/23/2004
Topology: Single Core model: AMD Athlon XP 3000+ bits: 32 type: UP
L2 cache: 256 KiB
Speed: 798 MHz min/max: N/A Core speed (MHz): 1: 798
Card-1: NVIDIA NV17M [GeForce4 420 Go 32M] driver: N/A
Display: server: X.Org 1.16.4 driver: fbdev,modesetting,nouveau
unloaded: nv,vesa resolution: 1024x768~N/A
OpenGL: renderer: Gallium 0.4 on llvmpipe (LLVM 3.5 128 bits)
v: 3.0 Mesa 10.3.2
Card-1: NVIDIA nForce3 Audio driver: snd_intel8x0
Sound Server: ALSA v: k4.4.10-antix.1-486-smp
Card-1: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
driver: 8139too
IF: eth0 state: unknown speed: 100 Mbps duplex: full
mac: 00:0f:b0:49:25:34
Card-2: Broadcom BCM4306 802.11b/g Wireless LAN driver: b43-pci-bridge
IF-ID-1: wlan0 state: down mac: 00:90:4b:a3:19:fe
HDD Total Size: 55.89 GiB used: 3.08 GiB (5.5%)
ID-1: /dev/sda vendor: Toshiba model: MK6025GAS size: 55.89 GiB
ID-1: / size: 9.50 GiB used: 3.08 GiB (32.4%) fs: ext3 dev: /dev/sda1
ID-2: swap-1 size: 2.45 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
System Temperatures: cpu: 62.0 C mobo: N/A
Processes: 119 Uptime: 1d 6h 32m Memory: 1.23 GiB used: 117.0 MiB (9.3%)
Shell: bash inxi: 3.0.10
And here's the inxi from the P-III that uses the GeForce2 just fine:
System: Host: deskpro Kernel: 4.4.10-antix.1-486-smp i686 (32 bit)
Distro: antiX-16_386-full Berta Cáceres 26 June 2016
Machine: Device: desktop System: Compaq product: Deskpro
Mobo: Compaq model: 0684h
BIOS: Compaq v: 686P2 v2.04 date: 08/25/2000
CPU: Single core Pentium III (Coppermine) (-UP-) cache: 256 KB
speed: 996 MHz (max)
Graphics: Card: NVIDIA NV11 [GeForce2 MX200]
Display Server: X.Org 1.16.4 drivers: nouveau (unloaded: modesetting,fbdev,vesa)
Resolution: 1024x768@85.00hz
GLX Renderer: Mesa DRI nv11 x86/MMX/SSE
GLX Version: 1.2 Mesa 10.3.2
Audio: Card Intel 82801BA/BAM AC'97 Audio Controller driver: snd_intel8x0
Sound: ALSA v: k4.4.10-antix.1-486-smp
Network: Card: Intel 82801BA/BAM/CA/CAM Ethernet Controller driver: e100
IF: eth0 state: up speed: 100 Mbps duplex: full
mac: 00:02:a5:04:34:81
Drives: HDD Total Size: 268.1GB (2.6% used)
ID-1: /dev/sda model: Maxtor_6L100P0 size: 100.0GB
ID-2: /dev/sdb model: WDC_WD1600JB size: 160.0GB
ID-3: USB /dev/sde model: USB_Flash_Drive size: 8.0GB
Partition: ID-1: / size: 15G used: 5.0G (36%) fs: ext4 dev: /dev/sdb7
ID-2: swap-1 size: 1.08GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors: None detected - is lm-sensors installed and configured?
Info: Processes: 137 Uptime: 1 day Memory: 131.8/496.8MB
Client: Shell (bash) inxi: 2.3.8
I notice that the working antiX is running nouveau without kernel modesetting and the non-working MX-16 is using modesetting.
You might try pressing the "e" key at the grub screen and adding nomodeset after the quiet on the boot line to keep the MX-16 install from using kernel modesetting instead of nouveau's. If that works you use boot options in MX-Tools to make that change permanent.
Thank you, I tried that but the nouveau driver is still not added as a kernel module. I think I need to get nouveau installed as a kernel module driver in order for Xorg to use it. Should I be trying this from a live USB? I just made the nomodeset to the installed system's grub entry.
Here's a copy of the inxi and lsmod and modprobe for this MX-16.1 system:
sean@mx16:~
$ sudo inxi -Flx
[sudo] password for sean:
System: Host: mx16 Kernel: 3.16.0-4-686-pae i686 bits: 32 compiler: gcc v: 4.8.4
Desktop: Xfce 4.12.2 Distro: MX-16.1_386 Metamorphosis 8 June 2017
base: Debian GNU/Linux 8 (jessie)
Machine: Type: Laptop System: Hewlett-Packard product: Pavilion zv5200 (PT277UA#ABA) v: F.34
serial: CND5050SQV
Mobo: Compal model: 08A0 v: 32.41 serial: CND5050SQV BIOS: Hewlett-Packard v: F.34
date: 12/23/2004
CPU: Topology: Single Core model: AMD Athlon XP 3000+ bits: 32 type: UP arch: K8
L2 cache: 256 KiB
flags: nx pae sse sse2 bogomips: 1595
Graphics: Device-1: NVIDIA NV17M [GeForce4 420 Go 32M] vendor: Hewlett-Packard driver: N/A
bus ID: 01:00.0
Display: server: X.Org 1.16.4 driver: fbdev,nouveau unloaded: modesetting,vesa
resolution: 1024x768~76Hz
OpenGL: renderer: Gallium 0.4 on llvmpipe (LLVM 3.8 128 bits) v: 3.0 Mesa 12.0.3
Audio: Device-1: NVIDIA nForce3 Audio vendor: Hewlett-Packard driver: snd_intel8x0 v: kernel
bus ID: 00:06.0
Sound Server: ALSA v: k3.16.0-4-686-pae
Network: Device-1: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter driver: 8139too
v: 0.9.28 port: 7000 bus ID: 02:01.0
IF: eth0 state: unknown speed: 100 Mbps duplex: full mac: 00:0f:b0:49:25:34
Device-2: Broadcom BCM4306 802.11b/g Wireless LAN vendor: Hewlett-Packard driver: N/A
port: 7000 bus ID: 02:02.0
Drives: Local Storage: total: 55.89 GiB used: 6.00 GiB (10.7%)
ID-1: /dev/sda vendor: Toshiba model: MK6025GAS size: 55.89 GiB temp: 52 C
Partition: ID-1: / size: 16.88 GiB used: 6.00 GiB (35.6%) fs: ext3 dev: /dev/sda7
label: rootMX16
Sensors: System Temperatures: cpu: 65.0 C mobo: N/A
Info: Processes: 137 Uptime: 2m Memory: 1.23 GiB used: 165.3 MiB (13.1%) Init: SysVinit
runlevel: 5 Compilers: gcc: 4.9.2 Shell: bash v: 4.3.30 inxi: 3.0.30
sean@mx16:~
$ lsmod
Module Size Used by
cpufreq_userspace 12477 0
cpufreq_powersave 12422 0
cpufreq_stats 12694 0
cpufreq_conservative 13872 0
bnep 17184 2
bluetooth 335981 5 bnep
6lowpan_iphc 16548 1 bluetooth
rfkill 18387 2 bluetooth
uinput 17068 1
nfsd 236992 2
auth_rpcgss 45765 1 nfsd
oid_registry 12387 1 auth_rpcgss
nfs_acl 12463 1 nfsd
nfs 168022 0
lockd 73443 2 nfs,nfsd
fscache 44782 1 nfs
sunrpc 211375 6 nfs,nfsd,auth_rpcgss,lockd,nfs_acl
fuse 81592 3
ecryptfs 83869 0
loop 21987 0
parport_pc 26004 1
ppdev 16686 0
lp 12766 0
parport 35213 3 lp,ppdev,parport_pc
dm_crypt 22171 0
video 21844 0
joydev 16847 0
ttm 72222 0
drm_kms_helper 44450 0
drm 207686 2 ttm,drm_kms_helper
i2c_algo_bit 12647 0
processor 27146 0
thermal_sys 27122 2 video,processor
evdev 17136 6
serio_raw 12737 0
snd_intel8x0m 17500 0
snd_intel8x0 30521 2
k8temp 12482 0
snd_ac97_codec 96151 2 snd_intel8x0,snd_intel8x0m
snd_pcm 78128 3 snd_ac97_codec,snd_intel8x0,snd_intel8x0m
yenta_socket 38561 0
pcmcia_rsrc 17292 1 yenta_socket
snd_timer 26149 1 snd_pcm
snd 55101 9 snd_ac97_codec,snd_intel8x0,snd_timer,snd_pcm,snd_intel8x0m
soundcore 12890 1 snd
ac97_bus 12462 1 snd_ac97_codec
shpchp 30673 0
ext4 450845 1
crc16 12327 2 ext4,bluetooth
mbcache 17027 1 ext4
jbd2 72964 1 ext4
crc32c_generic 12576 1
btrfs 858938 0
xor 25716 1 btrfs
raid6_pq 95207 1 btrfs
dm_mod 83065 1 dm_crypt
sg 25573 0
sd_mod 43732 2
crc_t10dif 12399 1 sd_mod
crct10dif_generic 12517 1
crct10dif_common 12340 2 crct10dif_generic,crc_t10dif
ata_generic 12450 0
pata_amd 13094 1
ohci_pci 12704 0
libata 161900 2 pata_amd,ata_generic
ssb 51408 0
psmouse 93505 0
ehci_pci 12464 0
ohci_hcd 42566 1 ohci_pci
ehci_hcd 64933 1 ehci_pci
mmc_core 91803 1 ssb
pcmcia 44245 1 ssb
pcmcia_core 18024 3 pcmcia,pcmcia_rsrc,yenta_socket
8139too 30087 0
8139cp 26153 0
mii 12595 2 8139cp,8139too
scsi_mod 164132 3 sg,libata,sd_mod
usbcore 171098 4 ohci_hcd,ohci_pci,ehci_hcd,ehci_pci
usb_common 12408 1 usbcore
i2c_nforce2 12527 0
i2c_core 36838 4 drm,drm_kms_helper,i2c_algo_bit,i2c_nforce2
sean@mx16:~
$ modprobe nouveau
modprobe: ERROR: could not insert 'nouveau': Operation not permitted
sean@mx16:~
$ su
Password:
root@mx16:/home/sean# modprobe nouveau
modprobe: ERROR: could not insert 'nouveau': No such device
I don't believe "nomodeset" is for disabling the modesetting driver but I could be mistaken. I know it is used to stop all modesetting drivers, including nouveau, from taking over control of the consoles.
If you want to use nouveau on a live system then use the cheat "xorg=nouveau". I believe nouveau is still being used to control the consoles even when the "modesetting" driver is being used for X. When you install, make sure you carry over the live system changes to the installed system.
If you want to try using nouveau on an installed system then run:This should cause the nouveau driver to be used when you restart X (log out of X Windows and log in again).
I believe Xorg changed (and keeps changing) which default drivers it uses. Usually the modesetting driver is preferred, especially for newer hardware. Since we cater to older systems we adjust the xorg defaults when needed.
Also, as a point of clarification, there are usually 2 drivers involved. The kernel driver and the xorg driver. I have a table of kernel drivers with their associated xorg drivers (from a few years back). The xorg modules are in the directory /usr/lib/xorg/modules/drivers/ while the kernel modules are under /lib/modules/$KERNEL_VERSION/. Sometimes they have the same name and sometimes they have different names.
If any of these work, please post the output of "lspic -nn" so I can know the pci-id of your graphics card. We will then have the live system select nouveau by default for that card. It is sort of an ongoing battle to clean up after the problems with Xorg creates with its default selections. TBH, I'm still not caught up from last year.
HTH
sudo make-xorg-conf -o /etc/X11/xorg.conf nouveau
HTH
-- Richard Feynman
-- Richard Feynman
H'mm. This is a problem. I believe it is related to the already loaded "drm" and "drm_kms_helper" modules. If you boot live with "xorg=nouveau" also use the "bp=b9" cheat. This will give you a bash shell before init (and udev) run. From there you should be able to "modprobe nouveau". I was able to do this in Virtual Box.seaken64 wrote: ↑Tue Jan 15, 2019 1:46 am Thank you, I tried that but the nouveau driver is still not added as a kernel module. I think I need to get nouveau installed as a kernel module driver in order for Xorg to use it. Should I be trying this from a live USB? I just made the nomodeset to the installed system's grub entry.
root@mx16:/home/sean# modprobe nouveau modprobe: ERROR: could not insert 'nouveau': No such device
If that works, we still need to figure out how to automate it in live (may be easy) and implement it on the installed system.
-- Richard Feynman
-- Richard Feynman
@ seaken64
I run antiX 17 one thing that I have notices after installing the os and reboot, I always check my grub boot file and remove nomodeset from the grub line. If I do not do this the system will not run on my Nvidia card. Movies and youtube run so much better plus I also go into nvidia settings > panel X server display configuration> advanded > Force Full
Composition Pipeline > tick da box > Apply. Reboot
I think this happens because I have to install using the advanced option and this is why nomodeset is left in the grub file.. etc/default/grub
This may not help you Good Luck
Main : MX 19.1-AHS (i3) 5.4.13-1~mx19+1, Asus B450-i AMD 5 3600 , 32gb Hyper-X 3200 , GTX970 .
What is the output of the Command?
Also check into make sure nouveau is not blacklisted. It is usually blacklisted so will not load if you have installed nvidia drivers.
lsmod
Also check in
/etc/modprobe.d/
Seaken64, for loading the nouveau module correctly you have to blacklist nvidiafb module
Please look here
https://www.antixforum.com/forums/topic ... -question/
https://www.antixforum.com/forums/topic ... post-13891
Please look here
