One question only?
cjos
One question only?
#1 Post by cjos »
Is it one question at a time?
Cjos
kc1di
Re: One question only?
#2 Post by kc1di »
Hi Cjos,
I'm not sure exactly what you are asking , but if your talking about how many questions per thread. Normally it is best to ask just one question per thread unless they are very closely related. IE, if you have wireless problem, you should not ask in the same thread about a printer problem they should be separate subject lines.
Hope this helps.
#3 Post by richb »
Did you really intend to post this in the Mepis Forum? I suspect not. It is more properly in Administration>Site Help.
cjos
#4 Post by cjos »
kc1di wrote: Sat Jan 12, 2019 10:34 am Hi Cjos,
Hope this helps.
It certainly does, many thanks for that.
Getting into gear with a new (for me) forum, was not easy, so when I got a red lined quote during my typing, saying something like only one, I decided to ask the question to save any confrontation,
Cheers,
Cjos
cjos
#5 Post by cjos »
richb wrote: Sat Jan 12, 2019 11:40 am Did you really intend to post this in the Mepis Forum? I suspect not. It is more properly in Administration>Site Help.
Hi, sorry if this is in the wrong place. Yes, I am still in the learning curve.
On another matter, some Forums do email notification, which helps the Senior citizens like me. Can that happen here?
Many thanks for your help, it is much appreciated.
Cjos
cjos
#6 Post by cjos »
Hope this helps.
Thank you that is most helpful.
Cjos
"You cannot make another post so soon after your last." How soon?
#7 Post by richb »
OK, I moved it.
You can setup mail notification in the User Control Panel. Left click on your username in the upper right corner, then User Control Panel. Click on User Notifications on the right, bottom of the list.
You must wait 60 seconds between posts.
Return to “Site Help”
