Advice needed (Solved)
j2mcgreg
Re: Advice needed
#11 Post by j2mcgreg »
Thanks to all that responded. The re-install of Win 10 worked and I have a working laptop again although definitely not my OS of choice. Although I'm sure that in time that problem will be solved as well.
Re: Advice needed (Solved)
#12 Post by Stevo »
You could check out MX 18, as its updated graphics stack might support the newer Vega GPUs.
j2mcgreg
#13 Post by j2mcgreg »
That's my intention, but I'm going to wait until the final version is issued. I also have two five year old desktops. One is running 17.1 and the other is running the new beta.
j2mcgreg
#14 Post by j2mcgreg »
MX 18 Final wouldn't install and I got the same errors as before. I think that a bios update is my only option and there are 3 available for this laptop. Acer is unfortunately vague about what each update actually does so I am going to have to do some research before I decide on which one to apply (if any). The saga continues.
