User contributed splash themes
Any background image or other artwork submissions must include copyright information and explicit permission of the image's original creator to use the image. This includes a direct post of the image or links to a compiled image archive.
#1 Post by Jerry3904 »
This thread is for users to post their splash creations. Any original art work should be identified in a text document titled "Source"
Re: User contributed splash themes
#2 Post by Jerry3904 »
So, you might be asking yourself: how can I create a splash theme?
Complicated answer: covered by a series of blog posts that are linked in the MX Boot options HELP file. My goal is to work through all that one of these days when I have nothing to do...
Simpler answer: you use the example plymouth plugin script "script.script" located in /usr/share/plymouth/themes/script/. Example:
  • Dolphin_Oracle created the striking theme mx-linux this way. I ran a diff on the original and his script.script for the new theme, and you can see the small number of changes that he made (first number of each section is the line number):
    1c1
    < # This is an example plymouth plugin script
    > # mx script theme, modified from debian script theme script.script
    6c6
    < logo.image = Image("special://logo");
    > logo.image = Image("mx_wall_3_night.png");
    8c8,10
    < logo.opacity_angle = 0;
    > logo.opacity_angle =0;
    > mx_logo.image = Image("MX-logo.png");
    > mx_logo.sprite = Sprite(mx_logo.image);
    14,18c16,20
    <         logo.opacity_angle += ((2 * 3.14) / 50) * 0.5;  # 0.5 HZ
    <         min_opacity = 0.3;
    <         opacity = (Math.Cos(logo.opacity_angle) + 1) / 2;
    <         opacity *= 1 - min_opacity;
    <         opacity += min_opacity;
    > #        logo.opacity_angle += ((2 * 3.14) / 50) * 0.5;  # 0.5 HZ
    > #        min_opacity = 0.3;
    > #        opacity = (Math.Cos(logo.opacity_angle) + 1) / 2;
    > #        opacity *= 1 - min_opacity;
    > #        opacity += min_opacity;
    21c23,26
    <         logo.sprite.SetOpacity (opacity);
    > 	logo.z = -10000;
    > 	mx_logo.sprite.SetX (Window.GetX() + Window.GetWidth()  / 2 - mx_logo.image.GetWidth()  / 2);
    >         mx_logo.sprite.SetY (Window.GetY() + Window.GetHeight() / 2 - mx_logo.image.GetHeight() / 2);
    > #       logo.sprite.SetOpacity (opacity);
    We'll let him comment on those changes--I'm not sure there is much beyond the two image changes
  • image files being used must be placed in the same folder
  • a rewritten plymouth file (here: mx-linux.plymouth) needs to be created with the crucial middle section pointing to locations:
    [Plymouth Theme]
    Name=Script
    Description=Script example plugin.
    ModuleName=script
    [script]
    ImageDir=/usr/share/plymouth/themes/mx-linux
    ScriptFile=/usr/share/plymouth/themes/mx-linux/script.script
    [script-env-vars]
    example_env_var=example env var value
Simplest answer: you adapt one that already exists and works. This is what we have done to generate some of those in the beta splash theme package. Example:
  • User Gerson first found the beautiful animated theme dandelion, and switched the logo. We then substituted a different logo and deleted the existing Debian one. Ta-dah!
Note that if you change any logo or background you must revise the *.plymouth file as indicated above.
Ready to get started? :whoknows:
Gerson
Re: New app: MX Boot Options
#3 Post by Gerson »
<MOD: moved this to here from the testing forum>
Use the MX logo to add it to this Plymouth theme, Peter-Rabbit; It's not my responsibility, I just modified it, you can download it from this link.
G. Translate:
Usé el logo de MX para agregarlo a este tema de Plymouth, Peter-Rabbit; no es de mi autoría, solo lo modifiqué, pueden descargarlo desde este enlace.
#4 Post by asqwerth »
Gerson wrote: Thu Aug 09, 2018 3:35 pm <MOD: moved this to here from the testing forum>
G. Translate:
Use el logo de MX para agregarlo a este tema de Plymouth, Peter-Rabbit; no es de mi autoría, solo lo modifiqué, pueden descargarlo desde este enlace.
That is very cute!
clicktician
#5 Post by clicktician »
Jerry3904 wrote: Tue Aug 07, 2018 12:42 pm This thread is for users to post their splash creations. Any original art work should be identified in a text document titled "Source"
... if someone is looking for ideas...
I have a custom boot splash, lightdm login screen, and lock screen. But the reason isn't vanity or pride. Haha.
I have a rule: Any portable device that leaves my home or office must bear my e-mail address, cellphone number and reward offer for its safe return.
Instead of a sticker on the case of my MX tablet, I decided to display that info on the screen using customized art work (not very flexible).
I bet I'm not the only person who does this.
A smarter guy than I am could probably script-up an MX feature that would allow any user to display custom text on their boot, login, and lock screens.
proskehy
#6 Post by proskehy »
I'm not sure if that was the intention with the MX Linux logo, but when I see it, I see a windmill behind two hills. So I made a simple boot splash, using the existing dandelion-mx theme, somewhat building on that idea :)
I uploaded the theme to GitHub: https://github.com/proskehy/MXLinux_Windmill
#7 Post by Jerry3904 »
Thanks very much for the contribution! We'll take a look.
On the logo: it combines the pyramids from the old Mepis logo with the X of antiX.
Oh: and welcome to the Forum!
#8 Post by asqwerth »
Jerry3904 wrote: Mon Nov 26, 2018 10:40 am Thanks very much for the contribution! We'll take a look.
On the logo: it combines the mountains from the old Mepis logo with the X of antiX.
Welcome.
Jerry, I thought they were pyramids originally, not mountains.
#9 Post by richb »
Yes, They were pyramids.
#10 Post by Jerry3904 »
Yeah, meant that. Was too early in the am.
Locked
Return to “MX Art”
