I think this is not the case, because my mouse is connected to the PS2 port and it is moving fine during lag, only system and apps do not respond (when i hover over a button or do the click or scrolling web page mouse moves, but not scrollbars - lag), also the music playback is lagged at that times.clicktician wrote: ↑Thu Nov 08, 2018 3:23 pmAre your mouse and keyboard also USB devices? <I don't know> If so, they are sharing the same buss as your busy disk device.
Computer is lagging when there is high I/O on ext. HDD
Re: Computer is lagging when there is high I/O on ext. HDD
OS: MXLinux 17, systemd; GPU: AMD Radeon RX 560
Well, if MX is installed on your internal hard drive and not running off of a USB stick/drive like your torrent and crypt are, then it can't be a USB buss issue.
USB 3 should be way fast enough to handle the bandwidth from a spinning disk.
Have you tried nicing the IO like Felix suggested? When you kill the HDD and the encrypted drive and remove them, does the problem go away or does it still act sluggish?
The Liquorix kernel touts itself at being more responsive, so I wonder if trying that (keep your present kernel as a backup!) would make any difference.
