antiX Screenshots
Re: antiX Screenshots
#41 Post by anticapitalista »
He's using fluxbox not MATE
#42 Post by asqwerth »
male wrote: Thu May 17, 2018 10:01 am Two Conky and antiX17
A "different weather" with the TeoBigusGeekus script
and a RadioTray-Conky from loutch. Wow! ;)
Wow is the word.
Could you post the text for your weather and radiotray conkies?
#43 Post by Jerry3904 »
That is really fine, and very elegant.
male
#44 Post by male »
Many thanks to you're ;)
asqwerth wrote:Could you post the text for your weather and radiotray conkies?
Of course
If you agree, I'll do it here, KoO's: Conky Helps and Stuff
rich
#45 Post by rich »
Jerry3904 wrote: Mon May 07, 2018 9:02 am To bring up and reword an old joke: what's the last thing that goes through a mayfly's mind when it hits the windshield?
Glass?
#46 Post by Jerry3904 »
Hint: it's a body part...
rich
#47 Post by rich »
Oh ooookay. It was bugging me, but I looked it up
KoO
#48 Post by KoO »
@male
male wrote: Thu Mar 15, 2018 9:08 am antiX17 - fluxbox, with three conky' s ;)
Could I have a link for the top barline conky pls.
Do you know how to get rid off this line below conky on fluxbox and is stealing screen space..?
Thanks
male
#49 Post by male »
KoO wrote:Could I have a link for the top barline conky pls.
I'll be back, I have to search (I don't have a link, because I developed it myself)
I don't understand what you mean.
show your conkyrc ;)
male
#50 Post by male »
oben_Jan12rc
### pkill -xf "conky -c /home/male/Jan2012/oben_Jan12rc" &
###  Begin Window Settings  ##################################################
# Create own window instead of using desktop (required in nautilus)
own_window yes
#own_window_type normal  #panel
own_window_transparent yes
own_window_hints undecorated,below,skip_taskbar,skip_pager
#own_window_colour black
#own_window_class Conky
#own_window_title OneLiner
# Use the Xdbe extension? (eliminates flicker)
# It is highly recommended to use own window with this one
# so double buffer won't be so big.
double_buffer yes
### ARGB can be used for real transparency
### NOTE that a composite manager is required for real transparency.
### This option will not work as desired (in most cases) in conjunction with
### own_window_type override
#own_window_argb_visual yes
### When ARGB visuals are enabled, this use this to modify the alpha value
### Valid range is 0-255, where 0 is 0% opacity, and 255 is 100% opacity.
#own_window_argb_value 200
minimum_size 1660 0 ## width, height
maximum_width 1660  ## width, usually a good idea to be '=' or '>' minimum width
gap_x 5 # left-right
gap_y 5 # up-down
alignment top_left
###################################################  End Window Settings  ###
###  Font Settings  #########################################################
# Use Xft (anti-aliased font and stuff)
use_xft yes
#xftfont DejaVu Sans Mono:size=9
xftfont monofur:size=10
# Alpha of Xft font. Must be a value at or between 1 and 0 ###
xftalpha 0
# Force UTF8? requires XFT ###
override_utf8_locale yes
draw_shades no
default_shade_color black
draw_outline no # amplifies text if yes
default_outline_color black
uppercase no
######################################################  End Font Settings  ###
###  Color Settings  #########################################################
default_shade_color grey
default_color DCDCDC #220 220 220    Gainsboro
color0 8FBC8F #143 188 143    DarkSeaGreen
color1 778899 #119 136 153    LightSlateGray #
color2 FF8C00 #255 140   0    DarkOrange
color3 7FFF00 #127 255   0    Chartreuse
color4 FFA07A #255 160 122    LightSalmon
color5 FFDEAD #255 222 173    NavajoWhite    #
color6 00BFFF #  0 191 255    DeepSkyBlue
color7 00FFFF #  0 255 255    Cyan
color8 FFFFFF #               Withe          #
color9 FFFF00 #255 255   0    Yellow
#color10 B22222 #178  34  34    FireBrick
#####################################################  End Color Settings  ###
###  Borders Section  ########################################################
draw_borders no
# Stippled borders?
stippled_borders 0
# border margins
border_inner_margin 0
border_outer_margin 0
# border width
border_width 0
# graph borders
draw_graph_borders no #yes
default_graph_size 15 40
#####################################################  End Borders Secton  ###
###  Miscellaneous Section  ##################################################
# Boolean value, if true, Conky will be forked to background when started.
background yes
# Adds spaces around certain objects to stop them from moving other things
# around, this only helps if you are using a mono font
# Options: right, left or none
use_spacer none
# Default and Minimum size is 256 - needs more for single commands that
# "call" a lot of text IE: bash scripts
text_buffer_size 256
# Subtract (file system) buffers from used memory?
no_buffers yes
# change GiB to G and MiB to M
short_units yes
# Like it says, ot pads the decimals on % values
# doesn't seem to work since v1.7.1
pad_percents 2
##############################################  End Miscellaneous Section  ###
update_interval 1
TEXT
${execpi 1800 bash /media/DATEN/francescoPC/Conky/Conky-Kalender/Waehrungen/rex-convert.sh}\
${goto 100}${color9}GPU:${color8} ${hwmon 2 temp 1}°\
 ${color7}${kernel}${color8}  CPU: ${color7}${if_match ${cpu cpu0} < 10}00${cpu cpu0}${color8}\
${else}${color7}${if_match ${cpu cpu0} < 100}0${cpu cpu0}${color8}\
${else}${color9}${cpu cpu0}${color8}\
${endif}${endif}\
 Mem: ${color7}${if_match ${memperc} < 10}00${memperc}${color8}\
${else}${color7}${if_match ${memperc} < 100}0${memperc}${color8}\
${else}${color9}${memperc}${color8}\
${endif}${endif}\
 root: ${color7}${if_match ${fs_used_perc /} < 10}00${fs_used_perc /}${color8}\
${else}${color7}${if_match ${fs_used_perc /} < 100}0${fs_used_perc /}${color8}\
${else}${color9}${fs_used_perc /}${color8}\
${endif}${endif}\
 Core0: ${color7}${hwmon 1 temp 2}°${color8}\
 Core1: ${color7}${hwmon 1 temp 3}°${color8}\
 Core2: ${color7}${hwmon 1 temp 4}°${color8}\
 Core3: ${color7}${hwmon 1 temp 5}°${color8}\
 sdb: ${color7}${execpi 600 hddtemp -n /dev/sdb}°${color8}\
 DL: ${downspeedgraph eth0 10,50 FFFF00 FF0000}\
  MB: ${color7}${hwmon 1 temp 2}°${color8}\
  UP: ${upspeedgraph eth0 10,50 FF0000 FFFF00}${color8}\
  FAN: ${color7}${hwmon 0 fan 1}\
${color8}|${color7}${hwmon 0 fan 2}\
${color8}|${color7}${hwmon 0 fan 3}\
${color8}|${color7}${hwmon 0 fan 4}${color8}\
  UID: ${color7}${exec id | cut -c5-8}${color8}\
  €  ${color7}${execpi 90 grep "GBP to EUR" /media/DATEN/francescoPC/Conky/Conky-Kalender/Waehrungen/convert/gbp.tmc.txt | cut -c12-17}${color8}\
 £  ${color7}${execpi 90 grep "EUR to GBP" /media/DATEN/francescoPC/Conky/Conky-Kalender/Waehrungen/convert/eur.tmc.txt | cut -c12-17}
I am not allowed to publish the currency script :lipsrsealed: ;)
Return to “antiX”
