New pinxi/inxi test: Disk vendor
h2-1
#1 Post by h2-1 »
I've been prompted to add in disk vendor to the Drives report.
pinxi is the development version of inxi now, for those who don't know, and runs completely independently of inxi and it's configs etc.
I have the working version in pinxi, so if you have pinxi, just update it:
pinxi -U
If you don't, shortcut install is:
cd /usr/local/bin; wget -O pinxi smxi.org/pinxi; chmod +x pinxi
which grabs it from github.
To test, run:
pinxi -zdxxx
and paste the output here.
If it does not show the vendor name, show this:
ls -l /dev/disk/by-id
and I should be able to get it fixed in most instances, not all, but most.
The more arcane usb storage devices etc you can plugin and test, the better.
Note that mmc/(sd cards) is a bit of a problem and doesn't always have the data, it varies widely, but most other storage types should work via one or another method in inxi.
inxi had some bugs with the model string that it turned out were actually bugs in how /sys is packing that data, which means a kernel bug of some type, so I bypassed /sys and default to getting it from /dev/disk/by-id string parsing.
This has the nice added bonus of also working for parsing the model strings of bsds, which is always a plus.
Thanks for looking, this feature will be in inxi 3.0.08 once I confirm it works on most weird and basically all standard real user systems.
# before bug/update fix
inxi -zdxxxy80
  HDD Total Size: 357.72 GiB used: 7.54 GiB (2.1%)
  ID-1: /dev/sda model: InnoDisk_Corp._- size: 119.24 GiB serial: <filter>
  rev: 25 temp: 30 C scheme: MBR
  ID-2: /dev/sdb model: INTEL_SSDSC2KW25 size: 238.47 GiB serial: <filter>
  rev: 002C scheme: MBR
  Message: No Optical or Floppy data was found.
# after bug/update fix
pinxi -dxxx -zy 80
  ID-1: /dev/sda vendor: InnoDisk model: mSATA 3ME3 size: 119.24 GiB
  serial: <filter> rev: 25 temp: 30 C scheme: MBR
  ID-2: /dev/sdb vendor: Intel model: SSDSC2KW256G8 size: 238.47 GiB
  serial: <filter> rev: 002C scheme: MBR
smxi/sgfxi site (manuals, how-to's, faqs) :: script forums :: Check out inxi sys info script!
Gordon Cooper
Re: New pinxi/inxi test: Disk vendor
#2 Post by Gordon Cooper »
Thanks h2-1. I will approach this very carefully!! Do not think my system is very weird (yet) !
rokytnji.1
#3 Post by rokytnji.1 »
harry@biker:~
$ pinxi -zdxxx
Drives:    HDD Total Size: 298.09 GiB used: 74.54 GiB (25.0%)
           ID-1: /dev/sda model: HGST_HTS545032A7 size: 298.09 GiB serial: <filter> rev: AC90
           scheme: MBR
           Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-7740H rev: 1.S1
           dev-links: cdrom,cdrw,dvd,dvdrw
           Features: speed: 24 multisession: yes audio: yes dvd: yes
           rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
harry@biker:~
$ pinxi -v
CPU: Dual Core Intel Core i5-3320M (-MT MCP-) speed/min/max: 1200/1200/3300 MHz
Kernel: 4.9.83-antix.1-686-smp-pae i686 Up: 13h 04m Mem: 496.0/15936.5 MiB (3.1%)
HDD: 298.09 GiB (25.0% used) Procs: 170 Shell: bash 4.3.30 pinxi: 3.0.07-8
I went ahead and updated pinxi on this laptop since I last corresponded with hydruga.
So old saved piinxi with changes suggested is only dated up to 4/26/18. Nothing changed by me suggested by hydruga after that date is lost in the wind now.
harry@biker:~
$ cd /usr/local/bin
harry@biker:/usr/local/bin
$ find pinxi.bkp
pinxi.bkp
I did have to Manually < chown as root > change permissions in my ~/.local/share/pinxi to my user name. Seems root owned it before and after my update.
Your fix identified my drive OK. But it is a old sata spinner. I still have to test on my chromebook.
h2-1
#4 Post by h2-1 »
rokytnji.1, very old and very new, and random usb drives, ssd drives, mmc, nvme, these are the most likely to not work. The old drives however were a very small set of IDs, and thus fairly easy to get right and complete. The vast numbers of various solid state drives however, not as easy, but getting around 98-99% is decent enough I suspect.
sunrat
#5 Post by sunrat »
Here ya go with 4 varied USB flash keys - the "Jetflash" is a 10 year old Transcend Jetflash:
pinxi -zdxxx
Drives:    HDD Total Size: 1.97 TiB used: 955.26 GiB (47.4%)
           ID-1: /dev/sda vendor: OCZ model: VERTEX2 3.5 size: 107.13 GiB
           serial: <filter> rev: 1.29 scheme: MBR
           ID-2: /dev/sdb vendor: Western Digital model: WD1001FALS-00J7B1
           size: 931.51 GiB serial: <filter> rev: 0K05 scheme: MBR
           ID-3: /dev/sdc vendor: Western Digital model: WD1001FALS-00J7B1
           ID-4: /dev/sdd type: USB vendor: Patriot model: Memory size: 29.84 GiB
           serial: <filter> rev: PMAP scheme: MBR
           ID-5: /dev/sde type: USB model: JetFlash TS4GJFV30 size: 3.83 GiB
           serial: <filter> rev: 8.07
           ID-6: /dev/sdf type: USB vendor: SanDisk model: Cruzer Edge size: 3.73 GiB
           serial: <filter> rev: 1.20 scheme: MBR
           ID-7: /dev/sdg type: USB vendor: Kingston model: DataTraveler 3.0
           size: 7.22 GiB serial: <filter> rev: PMAP scheme: MBR
           Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH20NS10 rev: EL00
           Features: speed: 48 multisession: yes audio: yes dvd: yes
#6 Post by richb »
Pretty standard stuff.
 pinxi -zdxxx
Drives:    HDD Total Size: 1.03 TiB used: 178.49 GiB (16.9%)
           ID-1: /dev/sda vendor: Seagate model: ST3320820SCE size: 298.09 GiB serial: <filter> rev: E
           scheme: GPT
           ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB serial: <filter> rev: 2B6Q
           scheme: GPT
           ID-3: /dev/sdc vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB serial: <filter> rev: 2B6Q
           scheme: GPT
           ID-4: /dev/sdd vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB serial: <filter> rev: 2B6Q
           scheme: MBR
           ID-5: /dev/sde type: USB vendor: SanDisk model: Extreme size: 58.43 GiB serial: <filter> rev: 0001
           scheme: MBR
#7 Post by timkb4cq »
Plugged in various stuff, all identified. The "Generic Flash Disk" label is correct. It's a promotional item (4 GB flash drive with a white led light in the cap) that shares its usb ID with a lot of products. The ID-3 drive is connected via a Cables Unlimited sata/ide -> usb adapter.
$ pinxi -zdxxx
Drives:    HDD Total Size: 3.12 TiB used: 2.00 TiB (64.0%)
           ID-1: /dev/sda vendor: Seagate model: ST33000651AS size: 2.73 TiB serial: <filter> rev: CC45
           temp: 47 C scheme: GPT
           ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB serial: <filter> rev: 1B6Q
           scheme: GPT
           ID-3: /dev/sdg type: USB vendor: Samsung model: SV0411N size: 37.31 GiB serial: <filter> rev: 0-08
           scheme: MBR
           ID-4: /dev/sdh type: USB model: MONSTER OD ADVANCE size: 115.11 GiB serial: <filter> rev: PMAP
           scheme: MBR
           ID-5: /dev/sdi type: USB model: Generic Flash Disk size: 3.76 GiB serial: <filter> rev: SHUS
           scheme: MBR
           ID-6: /dev/sdj type: USB vendor: SanDisk model: Cruzer Switch size: 7.45 GiB serial: <filter>
           rev: 1.26 scheme: MBR
           Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-S223Q rev: SB03
           Features: speed: 48 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram
           state: running
Richard
#8 Post by Richard »
richard@mx171:/usr/local/bin
$ pinxi -zdxxx
Drives: HDD Total Size: 585.00 GiB used: 87.35 GiB (14.9%)
ID-1: /dev/sda vendor: Samsung model: SSD 840 PRO Series size: 119.24 GiB serial: <filter> rev: 6B0Q
scheme: MBR
ID-2: /dev/sdb type: USB vendor: Sony model: Hard Drive size: 465.76 GiB serial: <filter> rev: 5438
scheme: MBR
Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-7740H rev: 1.S1 dev-links: cdrom,cdrw,dvd,dvdrw
Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram
state: running
Thanks. Seems to be working well.
h2-1
#9 Post by h2-1 »
Great samples. I actually had the Jetflash but removed it, heh, so I'll add that one back in since someone actually has it.
I don't like the handling of say, 'Patriot Memory' or 'Sony Hard Drive', in those cases, trimming out the vendor name from the model string doesn't seem to be that readable re the results.
I found a few classes of things that will not work, such as using usb adapters, say for ssd cards, in those cases, the adapter name itself is what shows up, not the actual card name, but that's out of my control since that's just what it is. The 'Generic... ' is likewise quite common, and can't really be properly handled unless I link the usb devices to the usb detections, which can then get the proper name, but that's much harder to do.
caprea
#10 Post by caprea »
helga@antix1:~
$ pinxi -zdxxx
  HDD Total Size: 2.17 TiB used: 82.85 GiB (3.7%)
  ID-1: /dev/sda vendor: Transcend model: TS256GSSD370 size: 238.47 GiB
  serial: <filter> rev: 5B scheme: MBR
  ID-2: /dev/sdb vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
  serial: <filter> rev: CC61 scheme: MBR
  ID-3: /dev/sdc type: USB vendor: Toshiba model: USB 2.5 -HDD size: 37.26 GiB
  serial: <filter> rev: 100 scheme: MBR
  ID-4: /dev/sdd type: USB vendor: Western Digital model: WD10JPVX-22JC3T0
  size: 931.51 GiB serial: <filter> scheme: MBR
  ID-5: /dev/sde type: USB vendor: Samsung model: HD080HJ size: 74.53 GiB
  ID-6: /dev/sdf type: USB vendor: Intenso model: Basic Line size: 7.28 GiB
  serial: <filter> rev: 8.07 scheme: MBR
  Optical-1: /dev/sr0 vendor: PIOR model: BD-RW BDR-209M rev: 1.10 dev-links: cdrom
  Features: speed: 125 multisession: yes audio: yes dvd: yes
The Toshiba and Samsung are old, maybe 10 years.
All working well, thanks.
Return to “antiX”
