[SOLVED] spacefm 1.0.6 upgrade-error in MX-17.1
Moin,
last weeks upgrade made the file manager spacefm to disappear within my
MX-17.1 installation due to a dependency issue.
Changing (patching) manually the dependency from libeudev1 to libudev1
within spacefm_1.0.6-1_amd64.deb fixed it.
Upgrading from spacefm-1.0.5 will result in un-installing spacefm.
As a very long time spacefm-user and a very long-time MX-user
unbelievable - my first post!!
Re: spacefm 1.0.6 upgrade-error in MX-17.1
Is the new spacefm coming from the antiX repository?
It would seem that allowing for both udev and eudev as alternative dependencies in the deb package would also work. Or we may have to build an MX version which will be seen as newer by apt.
yeah, we need to fix that deb. the depend needs to be either udev or eudev. BTW, udev should be provided by eudev.[Stevo wrote:Is the new spacefm coming from the antiX repository?
Yes, exactly - this is from the antix-repository (antix.list). As MX uses udev and antiX eudev having bothe alternativ dependencies (libeudev1|libudev1) for spacefm would satisfy both linux environments.Stevo wrote:Is the new spacefm coming from the antiX repository?
Wow, I thought the project was dead. I missed this announcement: http://ignorantguru.github.io/spacefm/news.html#1.0.6
It depends on whether the package creates the dependency automatically with the ${shlibs:Depends} variable if the maintainer could make it have the alternate Depends, though I guess it's worth a try to see if putting them in manually will work...I think doing that overrides the automatic one.
Does anyone know where the source for the antiX version is...oh, wait, it's in Sid. Is there any way we can talk antiX packagers into using an "-antix" suffix to their packages to allow for a possible smooth upgrade to ~mx versions and even a Buster-based MX, like the debian backports do?
Sorry about that - I will remove the latest version 1.0.6 from the antiX repository for now.
Wait, amending "that deb" (spacefm package) would amount to treating the symptom, not the problem, yes?yeah, we need to fix that deb. the depend needs to be either udev or eudev. BTW, udev should be provided by eudev.
AFAICT, the solution would be to amend both the libeudev1 and eudev packages, as follows:
Package: libeudev1
Provides: libudev1
Replaces: libudev1 (and do not state a version)
Package: eudev
Provides: udev
Replaces: udev (and do not state a version)
ref: https://debian-handbook.info/browse/sta ... ation.html
I'm building a MX package that will be seen as higher than the antiX one. If anti builds 1.0.6-1~antix for the antiX repo, that should not be seen as higher than our repo version, but will still be available to the antiX users.
The libeudev1 dependency was added automatically by shlibs, but I'm trying the alternate build-depends and depends method to see what comes out the other end...though just the alternate build-depends method should also work if the antiX eudev build stays in its own repo. I'm assuming that the package is libeudev-dev for antiX, since I don't know for sure.
As I have now the deb version 1.0.6 (manually patched) installed I'm quite happy with itStevo wrote:I'm building a MX package that will be seen as higher than the antiX one. If anti builds 1.0.6-1~antix for the antiX repo, that should not be seen as higher than our repo version, but will still be available to the antiX users.
as spacefm is extremly useful and powerfull. I do have spacefm on all my different linux instillations in addition to the default file manager.
Actually their is another issue within that deb-package (1.0.6) as within the postrm-file the remove-tag is missing which results in dpkg-error during remove: "postrm called with unknown argument'remove' " within in MX-17.1 and antiX-17.1!
Manualy patching this postrm by using the postrm from version 1.0.5 made dpkg happy again.
I've tested successively this patched install/remove on both MX-17.1 and antix-17.1.
