LibreOffice 6
newguy
Re: LibreOffice 6
#51 Post by newguy »
I should have specified that I used the MX upgrade program to get the latest batch of updates, including LibreOffice. I don't remember if the MX update app uses "apt upgrade" or "apt-get upgrade". In any case, I was using the app's upgrade function rather than dist-upgrade.
I'd like to add that I was using two English language packs (UK English and US English) when the error occurred.
Re: LibreOffice 6
#52 Post by dolphin_oracle »
newguy wrote:I should have specified that I used the MX upgrade program to get the latest batch of updates, including LibreOffice. I don't remember if the MX update app uses "apt upgrade" or "apt-get upgrade". In any case, I was using the app's upgrade function rather than dist-upgrade.
thanks, that helps.
Re: LibreOffice 6
#53 Post by dolphin_oracle »
ok, I can reproduce the error with apt-get upgrade.
in this case, libreoffice itself didn't update, as per my posts above. However, something else did update that causes the breakae and I'm trying to track that down.
Re: LibreOffice 6
#54 Post by dolphin_oracle »
getting close...found a couple of mismatched libraries. checking those out...
Re: LibreOffice 6
#55 Post by Adrian »
Great, thank you very much for getting to the bottom of this!
newguy
Re: LibreOffice 6
#56 Post by newguy »
Indeed, thanks for the quick work.
For the future, I wonder if it might be worth while to look at putting major application version bumps like this into a separate, Backports repo? I don't have Debian Backports enabled just to prevent surprise updates/breaks like this one. I'm okay with using older versions of LibreOffice or Firefox ESR rather than the latest packages for the sake of reliability/pleasant boredom.
Re: LibreOffice 6
#57 Post by Jerry3904 »
Well, it's been easily accessible in Debian Backports via MX Package Installer for 10 days or so, and our testing from there or by direct download was all clean.
What we probably might do next time is to move it to MX Test and let it sit there for a good while--something Devs will certainly discuss, thanks.
Re: LibreOffice 6
#58 Post by dolphin_oracle »
The problem turned out to be 2 libraries that were updating during the "apt-get upgrade" when they shouldn't have. These library packages are now updated with proper depends information so that shouldn't happen now. Main repos are updated already, mirrors should catchup over nite.
For those using the default mx-updater settings, or default synaptic settings, or "apt-get dist-upgrade" and "apt full-upgrade" there is no problem. The problem was only for those using the usually stable "apt-get upgrade" or "apt upgrade" methods.
Sorry for the inconveniences.
Re: LibreOffice 6
#59 Post by asqwerth »
newguy wrote:Indeed, thanks for the quick work.
...I don't have Debian Backports enabled....
Most people don't. They use the MX Packageinstaller (MXPI) instead.
MXPI is used for one-off installations of specific packages from Debian Backports, where that repo is temporarily turned on for the install, then automatically turned off again.
Thus there is really no need to have a separate backports repo. Just use MXPI if you have a specific package from Debian Backports in mind.
newguy
Re: LibreOffice 6
#60 Post by newguy »
As a follow-up to this issue, I tried out performing "apt-get dist-upgrade" on a second computer to see how it would go. I can confirm the MX team's findings that the dist-upgrade worked, installing LibreOffice 6 without any issues. So sticking with the default update tool settings does indeed provide a working office suite.
