Failed to install budgie desktop in MX
vamsi
Re: Failed to install budgie desktop in MX
#11 Post by vamsi »
I rarely use the ubuntu ppas i actually use them for icon themes and one ppa is for chromium and remaining all are icon theme ppa's
 sudo aptitude install gnome-tweak-tool budgie-desktop-doc budgie-desktop
and after that i typed n and again typed Y and Y that's it installed
i used this command and it installed after that when i update my system it is asking to remove this packages and it is gone for ever
i think possible the icon ppas's caused this issue before i didn't face this issue
#12 Post by Stevo »
Usually the icon PPAs are safe. I'd suspect that Chromium PPA has a lot more to do with it. Have you added other outside repos in the past, such as Sid or testing?
Anyway, this thread should definitely been in the MX-Modified section. I would have added the head-banging gif but my forehead is too sore.
#13 Post by Jerry3904 »
Moved it.
vamsi
#14 Post by vamsi »
No i never added any debian repos other than provided by MX
To install chromium i downloaded libconfig1 fontconfig deb packages and then i updated and thus installed chromium
However i did this before one time at that time i didn't faced any problem and i was able to install budgie at that time but now only..
Return to “MX Modified”
