LibreOffice 6
LibreOffice 6
Will the new LibreOffice 6 be coming to MX Linux in the near future?
Re: LibreOffice 6
the short answer is ...maybe. The guys have been playing with the packaging, but its got some quirks.lhb1142 wrote:Will the new LibreOffice 6 be coming to MX Linux in the near future?
Re: LibreOffice 6
It is pretty nice...
Re: LibreOffice 6
I hope that its installation problems are fixed pretty quickly. Just the fact that one can easily create epubs with it makes my mouth water.
Re: LibreOffice 6
You can install it yourself:
- Go to this page
- Carefully select from the little box "Choose your operating system," making sure you choose 64 or 32, and that the package is a (deb)
- Download and, if motivated, donate a bit (I always do b/c I depend on it for business)
- Right-click the downloaded tarball to "Extract Here"
- Click to enter the extracted folder, then right-click the DEBS folder > Open Terminal Here
- Now you should be in the DEBS folder (check the prompt), so run the code:
sudo dpkg -i *.deb
- When that has finished, LO 6 will be in the menu under Office, and can be put in Favorites or on a panel
Re: LibreOffice 6
- Gordon Cooper
Re: LibreOffice 6
Installation okay, no problems found yet.
- Fornhamfred
Re: LibreOffice 6
No problems with my system on 6, how do I remove version 5 as some files open in it instead of 6?
