Applications don't resize.
Being that I have the DPI set to 150 because of my eyes some menus from some applications can't be resized. I have to use Alt/right and left click in order to move the window but it won't resize. Resizing doesn't work from the boarder. I found this issue with advert-block and with Thunderbird when I open the Preferences window so far with this bug. System: Host: Crippled Kernel: 4.14.0-12.1-liquorix-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Machine: Device: desktop System: HP product: 510-p026 serial: N/A
Mobo: HP model: 81B4 v: 00 serial: N/A UEFI [Legacy]: AMI v: F.13 date: 08/02/2016
CPU: Quad core Intel Core i5-6400T (-MCP-) cache: 6144 KB
clock speeds: max: 2201 MHz 1: 2200 MHz 2: 2200 MHz 3: 2200 MHz 4: 1300 MHz
Graphics: Card: Intel HD Graphics 530
Resolution: 1366x768@59.81hz, 1920x1080@60.00hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2) version: 4.5 Mesa 13.0.6
Audio: Card Intel Sunrise Point-H HD Audio driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.14.0-12.1-liquorix-amd64
Network: Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller driver: r8169
IF: eth0 state: up speed: 100 Mbps duplex: full mac: ec:8e:b5:d8:80:88
Card-2: Intel Wireless 3165 driver: iwlwifi
IF: wlan0 state: down mac: 76:75:ef:aa:38:7c
Drives: HDD Total Size: 8001.5GB (19.5% used)
ID-1: /dev/sda model: WDC_WD4003FZEX size: 4000.8GB
ID-2: USB /dev/sdb model: Elements_107C size: 4000.8GB
Partition: ID-1: / size: 3.6T used: 1.5T (42%) fs: ext4 dev: /dev/sda3
ID-2: swap-1 size: 12.90GB used: 0.27GB (2%) fs: swap dev: /dev/dm-0
Sensors: System Temperatures: cpu: 31.0C mobo: 27.8C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 235 Uptime: 2 days Memory: 2165.7/11872.8MB
Client: Shell (quick-system-in) inxi: 2.3.54
Re: Applications don't resize.
Add Libre Office to the list. I just opened up Libre Office to check which version I had and the window is too tall and too narrow so I tried to resize it and it wouldn't resize just like the other programs I mentioned earlier.
Try changing your window decoration to something with a bigger frame so there's a bigger area for the mouse cursor to grab.
Or use Alt-F8 to make the cursor jump to a corner for resizing.
That doesn't work because there is nothing to grab onto on the bottom, it won't resize.dreamer wrote:Try changing your window decoration to something with a bigger frame so there's a bigger area for the mouse cursor to grab.
That doesn't work. All that does is let me grab the window to move it.Jerry3904 wrote:Or use Alt-F8 to make the cursor jump to a corner for resizing.
Are you sure? The cursor jumps to the corner and becomes an icon with the arrow and sides pointing like an "L." Make sure your window is unmaximized by clicking in the upper left corner to get a menu if need be.
That's built into Xfce is why I ask.
I played around with the libreoffice launcher app last nite (which I assume is what the OP is talking about).
While I could get it to resize, it does have a minimum height that I could not shrink it down past. I didn't check the size of the window though...I'll try to do that. My screen is larger than 1366x768.
Yes, I am 100% sure. I can move the window around to get to what I need to get to but it won't resize. But my bug report is when I click on the square on the boarder on the top to make it to resize it doesn't respond on some windows. I never experienced this issue on any previous MX distros. This bug is only on MX-17.Jerry3904 wrote:Are you sure? The cursor jumps to the corner and becomes an icon with the arrow and sides pointing like an "L." Make sure your window is unmaximized by clicking in the upper left corner to get a menu if need be.
I could resize it wider by dragging it but I can't resize it vertically and the square in the boarder doesn't respond at all.dolphin_oracle wrote:I played around with the libreoffice launcher app last nite (which I assume is what the OP is talking about).
