gqrx-sdr & gnuradio
Gordon Cooper
gqrx-sdr & gnuradio
Post by Gordon Cooper » Fri Apr 07, 2017 6:39 pm
Updates are available for gqrx-sdr now 2.6 , and gnuradio now 3.7.11 Would be grateful for these to be upgraded in the repo. No hurry as I'm still wrestling with the basics.
Thanks,
Gordon
Primary: Dell9010, MX-18, Win7, 120 SSD, WD 232GIB HD, 4GB RAM
Backup :Homebrew64 bit Intel duo core 2 GB RAM, 120 GB Kingston SSD, Seagate1TB.
MX-17.1 64bit. Also MX17, Kubuntu14.04 & Puppy 6.3.
Re: gqrx-sdr & gnuradio
Post by Stevo » Sun Apr 09, 2017 2:36 pm
I'll see about backporting them for the test repo.
Gordon Cooper
Post by Gordon Cooper » Sun Apr 09, 2017 7:44 pm
Stevo wrote:I'll see about backporting them for the test repo.
Thanks Steve, when you have spare time. Our local sdr guru is trying to get sdr working with Linux & I am hoping to convert him to MX.
Post by Stevo » Sun Apr 09, 2017 7:49 pm
The 3.7.11 gnuradio hasn't made it into any repositories at all, and I was looking at a daunting 40 patches for the previous version in Debian that might need refreshing or removing for 3.7.11. Yikes!
Gordon Cooper
Post by Gordon Cooper » Mon Apr 10, 2017 12:09 am
Maybe it could go on the back burner for a while (for ever?) and let someone else in another distro do the toil? The versions currently in the MX repo are working for me in MX.
xali
Post by xali » Thu Jan 18, 2018 12:47 pm
is it possible to have a newer version of gqrx?
Post by Stevo » Thu Jan 18, 2018 5:34 pm
I'll look into backporting that and gnuradio 3.7.11 from Debian testing to MX 17.
Post by Stevo » Thu Jan 18, 2018 9:22 pm
First attempts at a gnuradio backport failed fairly quick, but I tracked it down to a patch that Debian added to build against Buster's gcc-7. Disabling the patch has let me get at least halfway through the lengthy build so far on our gcc-6.
xali
Post by xali » Fri Jan 19, 2018 8:11 am
yes gnu radio is quite messy, i don't think that would be easy or possible. can something be done about mx16 also if possible?
#10
Post by Stevo » Fri Jan 19, 2018 2:32 pm
It turned out to require a total of eight backports for each architecture on MX 17, and gnuradio was a pretty lengthy build. I was lucky to find and disable two patches that caused build failures on gcc-6. MX 16 might require many more packages be backported first, but I hope to get time eventually. I'm kind of snowed under right now (heh...with almost nonstop 75-80 F days here) with Pale Moon and kernel updates, plus a lot of other smaller packages.
