Solved - lost Xfburn from menu on AntiX 17
namida12
#1 Post by namida12 »
How can I add Xfburn back to menu, as It is installed looking in Synaptic, but missing from the menu system.
Also trying to start the application in a terminal by typing "Xfburn" I get this info...
green250@antix250:~
$ Xfburn
bash: Xfburn: command not found
green250@antix250:~
caprea
Re: lost Xfburn from menu on AntiX 17
#2 Post by caprea »
rokytnji.1
#3 Post by rokytnji.1 »
Or. If positively sure it is installed
$ apt-cache policy xfburn
xfburn:
  Installed: 0.5.4-1
  Candidate: 0.5.4-1
  Version table:
 *** 0.5.4-1 500
        500 http://ftp.us.debian.org/debian stretch/main i386 Packages
        100 /var/lib/dpkg/status
Menu>Applications>Preferences>Menu Manager
Pretty simple to use. Edit: PS. You ran the command wrong in terminal. Lower case x instead of upper case X
#4 Post by Stevo »
namida12 wrote:How can I add Xfburn back to menu, as It is installed looking in Synaptic, but missing from the menu system.
green250@antix250:~
$ Xfburn
green250@antix250:~
Try "xfburn" instead of "Xfburn"?
namida12
#5 Post by namida12 »
xfburn:
  Installed: 0.5.4-1
  Candidate: 0.5.4-1
  Version table:
 *** 0.5.4-1 500
        500 http://ftp.us.debian.org/debian stretch/main amd64 Packages
Menu>Applications>Preferences>Menu Manager <--- xfburn is not listed
JR
namida12
#6 Post by namida12 »
Caprea,
Thanks for providing link...
Reinstalling the app did the trick.
JR
Return to “antiX”
