antiX-17 released
Spartak77
Re: antiX-17 released
#31 Post by Spartak77 »
Instructions about how to add icons-Launcher of programs on your desktop and panel in antiX are explained on the antiX Faq: https: //download.tuxfamily.org/antix/docs-antiX-15/FAQ/index.html
You must see the ROX section.
The link I mentioned to you is obviously in English, but I'm translating FAQ into Italian, so I can attach a file with the translated pages, even if they are not in the final version yet, I want to make checks in case of mistakes before to publish them. However, as you need it immediately, I attach the file for you of my provisional version.
Now I'm hurry but this evening I attach it to you.
Le indicazioni di come aggiungere icone-Launcher di programmi sul desktop, e sulla barra in basso, in antiX sono spiegate sulle antiX Faq: https://download.tuxfamily.org/antix/do ... index.html
devi vedere la sezione ROX.
Il link che ti ho indicato ovviamente è in lingua inglese, ma io le sto traducendo in italiano, perciò ti posso allegare un file con le faq tradotte, anche se non sono ancora nella versione definitiva, voglio fare dei controlli nel caso di eventuali errori prima di pubblicarle. Comunque visto che ti servono ti allego il file della mia versione provvisoria.
Ora sono di corsa ma entro questa sera te lo allego.
Ciao
Spartak77
#32 Post by Spartak77 »
It is more convenient to open a new tread on the Italian forum. I attach the FAQ file, translated into italian, there.
E' più comodo aprire un nuovo tread nel forum italiano. Attacco il file delle faq li. ciao
namida12
#33 Post by namida12 »
17.1 has been released: this link should be different...
antiX-17.1 version Torrent address page
https://antixlinux.com/download/
JR
Zoleeka88
#34 Post by Zoleeka88 »
Hi Everyone!
I am just wondering if I am using AntiX 17.0 on a really old computer and it was installed a while ago and I haven't used it since, is it possible to upgrade this system to AntiX 17.1 without a need of a fresh install or I have to fresh install AntiX 17.1 from its ISO? Thanks for your help and replies.
#35 Post by dolphin_oracle »
yes, although the system won't report itself as 17.1. (this is a design decision so that we know what iso the user starts from) 17.1 is built from the same repos as 17.
Zoleeka88
#36 Post by Zoleeka88 »
Thank you very much dolphin_oracle for the quick reply, it is great to know, I am gonna do the upgrading right now then :) Have a nice evening.
Return to “antiX”
