Installed anti-15 on ibm thinkpad 600.
Tried to get sound card working by using steps on mepis wiki page :Snd-cs4236.
Did step 1, copying and pasting configuration file into /etc/modprobe.d/alsa
Step 2 is where I have the problem:
running in root "update-modules" bash tells me that it cannot find the command.
Is there a new command or series of steps that does what "update-modules" did before it was removed from bash?
no sound from sound card on ibm thinkpad 600
Re: no sound from sound card on ibm thinkpad 600
Hi techseptic and welcome to the forum.
I'm not to skilled and I don't know much about AntiX 15 .. There is an AntiX / Mepis wiki that you might look at. Some of the other folks should be along soon. I'm 'guessing" that it may have something to do with GPG settings, but I don't know.
http://www.mepiscommunity.org/wiki/helpfiles
http://www.mepiscommunity.org/wiki/all
Kern...
Kern...
MX-19.2_x64 | System76 Galago UltraPro / Clevo W740SU | Intel Core i7-4770HQ | Intel Iris Pro Graphics 5200 | 16 GB DDR3 | Intel 530 series mSATA SSD - 240-GB | WD7500BPKX - 750-GB | Intel HD Audio.
you can try depmod -a
if the modules in question is already present, this step is probably unnecessary.
