List of MX-15 Manual translations
For suggestions, procedures and requests for translations of documentation and apps to languages other than English.
#1 Post by Jerry3904 »
In this thread I would like to keep track of translations that have been completed for at least Sections 1 and 3. I have changed the Manuals tab to point to a Translations page that lists available translations populated from posts on this thread.
(Probably going to have to change some of the other links pointing directly to the English Manual...)
BTW: some of our users may even want to produce a British English version to get rid of those Americanisms!
Re: List of MX-15 Manual translations
#2 Post by Jerry3904 »
A full Russian translation is now available by clicking the Manuals tab > MX-15 > Other languages: see <this page>.
:cool2: :cool2:
Many thanks to bicyclist56!
NOTE: this text is in html, so we may end up with a mixture of html and pdf files--we'll just have to see how it shakes out. Going to put any decision off for a while here.
bicyclist56
#3 Post by bicyclist56 »
Jerry3904 wrote:A full Russian translation is now available by clicking the Manuals tab > MX-15 > Other languages: see <this page>.
<this page> = http://www.mepiscommunity.org/wiki/help ... anslations
I found that in the Table of Contents links lead to the English version! We had to fix all of these references.
For example, instead:
mepiscommunity.org/user_manual_mx15/mxum.html#toc-Subsection-1.6
should be:
mepiscommunity.org/user_manual_mx15/Translations/mx15_Russian.html#toc-Subsection-1.6
Updated html file:
https://cloud.mail.ru/public/3LJg/VKAbRM27L
MX-18: Intel Celeron C1037U 8GB RAM 2x120GB SSD
MX-18: Intel Core i5-3317U 4GB RAM 32GB SSD
Slax-9: Intel Core i5-3317U 4GB RAM 8GB SSD
No Windows!
My blog (Russian) - https://bicyclist56.blogspot.com/p/mx-linux.html
#4 Post by Jerry3904 »
OK, uploaded the replacement file.
Hadn't thought about that yet, so thanks! We will have to figure out how to deal with that with future translations--it may be manual change is the only way, since a search/replace won't touch the links AFAIK. Need to do some web searching...
A minute later:
1) I can just open an html file in Leafpad and do the search/replace there.
2) Before we create a PDF in LO, we can follow the approach here, which uses the xml file itself.
Gordon Cooper
#5 Post by Gordon Cooper »
Have created a draft pdf and found that problem with the TOC links. May have found another work-around that does not need a manual
replace. Will advise you of results later in the day. There is the fact that all the links ( Help etc) in the translated manual will link to the
original English language data.
#6 Post by Jerry3904 »
I avoided internal links (cross refs) so I hope there won't be any.
The anual method is a single click search/replace, so not much effort.
Gordon Cooper
#7 Post by Gordon Cooper »
Chores for next few hours - but working with the translated Russian html, if I click on a link in the ToC, up comes the full manual again,
then click on a ToC link and it works correctly. Now to see if this behaviour is retained in the conversion to LO. Later today.
Edit: two hours later - no, it does not retain link info in LO conversion.
Gordon Cooper
#8 Post by Gordon Cooper »
I'm confused :confused: , which is nothing unusual.
Using Leafpad to view the html files; in the original English file, the ToC linking instructions are obvious and as expected. In the Russian
translation, there seem to be no ToC links.
In a Libre Office copy of the Russian Manual, the ToC link for 1.1 is this (see Screenshot) but a Ctrl/Click links back to the full Russian html
file - and the other ToC sections do the same.
bicyclist56
#9 Post by bicyclist56 »
But now:
Page not found
The requested page "/user_manual_mx15/Translations/mx15_%D0%A0%D1%83%D0%BA%D0%BE%D0%B2%D0%BE%D0%B4%D1%81%D1%82%D0%B2%D0%BE.html" could not be found.
We have forgotten to change the name in English? :(
No Windows!
Gordon Cooper
#10 Post by Gordon Cooper »
Yes, of course, it has already been translated. Thank you.
Return to “Translations”
