Youtube upgrade has killed minitube
m_pav
#1 Post by m_pav »
A picture is worth a thousand tears :bawling:
Mike P
Regd Linux User #472293
MX-tester
Re: Youtube upgrade has killed minitube
#2 Post by MX-tester »
......and that is not all they have buggered up! Other downloaders no longer work either!
#3 Post by Jerry3904 »
I'm sure it's just an accident...
Gaer Boy
#4 Post by Gaer Boy »
I've just updated youtube-dl and successfully downloaded a video from YouTube. The version is 2015.05.15
#5 Post by Stevo »
Gaer Boy wrote:I've just updated youtube-dl and successfully downloaded a video from YouTube. The version is 2015.05.25
I knew it. An evil version of you from the future, no doubt with an evil goatee!
Anyway, there's already a lengthy thread about Youtube, SMTube, and Minitube here on the forum.
For Minitube, you can use the 32 bit deb from the minitube homepage which has the developer's Google API key compiled in. 64 bit requires a newer libc6.
There's a new SMTube 15.5.10 in the test CR which also fixes the problem, and can be configured to download the videos with an external agent such as uget.
Gaer Boy
#6 Post by Gaer Boy »
Aaaargh! Typo corrected in post.
mmikeinsantarosa
#7 Post by mmikeinsantarosa »
Gaer boy wrote:Aaaargh!
Careful with word useage here. That one is reserved for when steveo is talking to me :p
...every "Talk like a pirate day' as in
"Mike, I think there's a new inkscape out... Aaaargh".
Last edited by mmikeinsantarosa on Fri May 15, 2015 3:35 pm, edited 1 time in total.
joany
#8 Post by joany »
Stevo wrote: For Minitube, you can use the 32 bit deb from the minitube homepage which has the developer's Google API key compiled in. 64 bit requires a newer libc6.
Yes, the new Minitube version 2.4 works very well with the modified YouTube. It's nice that you can play YouTube videos from within Minitube itself instead of having to open an external media player to watch them. You can also use a download agent like fatrat by selecting "Video > Copy the Video Stream URL" from the drop-down menu and pasting the URL from the clipboard.
2.4GHz AMD Athlon 4600+
#9 Post by Jerry3904 »
A little more detail here would be helpful...
mmikeinsantarosa
#10 Post by mmikeinsantarosa »
Jerry3904 wrote:A little more detail here would be helpful...
Looks like go to here and look for this (see image)
the 32 bit button gives you a minitube.deb file download. And from there run gdebi.
