I'm suspecting that a lot of the appearance and UI irritations I'm experiencing are due to the Oxygen theme I chose for this install. Which is odd (to me) since I've always had good success with it in the past. <shrug> I'm not happy with the other choices that came with the kde-standard package either.
So, can anyone recommend an Oxygen-like theme they like? I prefer a darkish theme, and am most happy with Oxygen's panel and icons.
What I'm really after is something that Warren would use. He and I always seemed to be on the same page when it came to this kind of stuff.
KDE theme recommendations?
- uncle mark
Acer Aspire 5250 -- MX 21 KDE
Re: KDE theme recommendations?
I believe Warren's default theme was "Elegance."
Gigabyte 990FXA-UD3, AMD FX-6100 hex-core, 3.3GHz, 8G, Radeon HD6570
- uncle mark
Thanks. That changed the Panel a bit (for the better), but didn't seem to effect much else. <shrug>DBeckett wrote:
Try installing "kwin-style-crystal" from the debian repo.
Then go to System Settings --> Workspace Appearance --> Window Decorations to tweak it.
And at the time, it was said we should check out the effects of the "Oxygen Theme", so I did. I do not know, where W.W. got the
theme from, maybe the PPAs. Remember, Debian stable is at least two years behind the fast trackers and what they are doing today.
Research, Research, Research, Before You Walk The Plank.
Registered Linux User # 398829
