MX-14/MEPIS-12 Repository: The couchdB thread
For Community Repository Package Requests and Status for MX-14
mmikeinsantarosa
Post by mmikeinsantarosa » Fri Mar 11, 2016 4:11 pm
couchdb-1.6.0 is now available for download from the test repo.(32 & 64 bit)
Apache CouchDB 1.6.0 Release Notes
CouchDB is a database that completely embraces the web. Store your data with JSON documents. Access your documents with your web browser, via HTTP. Query, combine, and transform your documents with JavaScript. CouchDB works well with modern web and mobile apps. You can even serve web apps directly out of CouchDB. And you can distribute your data, or your apps, efficiently using CouchDB’s incremental replication. CouchDB supports master-master setups with automatic conflict detection.
What's Fixed:
* :issue:`2200`: support Erlang/OTP 17.0 :commit:`35e16032`
* Fauxton: many improvements in our experimental new user interface, including
switching the code editor from CodeMirror to Ace as well as better support
for various browsers.
* Add the ``max_count`` option (:ref:`config/uuids`) to allow rate-limiting
the amount of UUIDs that can be requested from the :ref:`api/server/uuids`
handler in a single request (:ref:`CVE 2014-2668 <cve/2014-2668>`).
* :issue:`1986`: increase socket buffer size to improve replication speed
for large documents and attachments, and fix tests on BSD-like systems.
:commit:`9a0e561b`
* :issue:`1953`: improve performance of multipart/related requests.
:commit:`ce3e89dc`
* :issue:`2221`: verify that authentication-related configuration settings
are well-formed. :commit:`dbe769c6`
* :issue:`1922`: fix CORS exposed headers. :commit:`4f619833`
* :issue:`1795`: ensure the startup script clears the pid file on termination.
:commit:`818ef4f9`
* :issue:`1962`: replication can now be performed without having write access
to the source database (:commit:`1d5fe2aa`), the replication checkpoint
interval is now configurable (:commit:`0693f98e`).
* :issue:`2025`: add support for SOCKS5 proxies for replication.
:commit:`fcd76c9`
* :issue:`1930`: redirect to the correct page after submitting a new document
with a different ID than the one suggested by Futon. :commit:`4906b591`
* :issue:`1923`: add support for `attachments` and `att_encoding_info` options
(formerly only available on the documents API) to the view API.
:commit:`ca41964b`
* :issue:`1780`: upgrade password hashes from SHA-1 to PBKDF2 scheme on
successful authentication. :commit:`34888938`
* :issue:`2059`: allow run-time configuration of maximum URL length.
:commit:`f7ca266b`
* :issue:`2054`: accept gzipped JSON request bodies. :commit:`4d893387`
* Rename ``proxy_authentification_handler`` to ``proxy_authentication_handler``.
:commit:`c66ac4a8`
* :issue:`1647`: for failed replications originating from a document in the
`_replicator` database, store the failure reason in the document.
:commit:`08cac68b`
* :issue:`2053`: send better error messages when both `key` and `keys`
parameters are specified in view requests. :commit:`2bc07840`
* :issue:`2040`: send better error messages when incorrect checksums
are encountered during compaction. :commit:`e7fdc16a`
* :issue:`2028`: allow intermedia certificates when using SSL/TLS.
:commit:`2d080449`
* :issue:`2031`: fix rewriting of paths with query string parameters.
:commit:`37c84596`
* Numerous improvements to the documentation.
Here's a tutorial to check if you installed it correctly; https://pouchdb.com/guides/setup-couchdb.html
Let us know how it plays!
- mike
LT: MX17.1 Quad Core model: Intel Core i7-6820HQ Kernel: 4.16.0-12.1-liquorix-amd64 (64 bit)
darth.severus
Re: MX-14/MEPIS-12 Repository: The couchdB thread
Post by darth.severus » Mon Mar 14, 2016 12:11 pm
I was using this:
And got:
$ sudo apt-get update && apt-cache show couchdb
Package: couchdb
Version: 1.2.0-5
Is it in mepis12cr? Can I use this with MX14?
Acer Extensa 2519 with 4GB RAM v: V1.24 | Intel Celeron N3060 2.4 GHz | Intel HD Graphics 400 (Braswell)
v3g4n
Post by v3g4n » Mon Mar 14, 2016 12:46 pm
mmikeinsantarosa wrote:I use 2 m12 VMs, a 32 and a 64 bit. The m12 32 bit builds are used in MX-14. I only have MX-14 VMs for testing already built packages.
- mike
From the looks of it mike builds the packages on M12 and then simply tests the packages with MX14 to make sure they install and run properly. So I would say yes you should be able to install from mepis12cr. If I'm not mistaken they both (Mepis 12 and MX 14) are based on Wheezy so they should be compatible with each other.
Edit: removed link since kmathern has a link ;)
kmathern
Post by kmathern » Mon Mar 14, 2016 12:47 pm
darth.severus wrote:...Is it in mepis12cr? Can I use this with MX14?
I see 1.6 in the mepis12cr testrepo: http://main.mepis-deb.org/mepiscr/testr ... c/couchdb/
edit: oops v3g4n posted the same
darth.severus
Post by darth.severus » Tue Mar 15, 2016 8:05 am
I should first have uninstalled it? EDIT: I did now, and it works. Thanks.
Selecting previously unselected package couchdb-common.
(Reading database ... 203001 files and directories currently installed.)
Unpacking couchdb-common (from .../couchdb-common_1.6.0-0mcr120+1_all.deb) ...
dpkg: error processing /var/cache/apt/archives/couchdb-common_1.6.0-0mcr120+1_all.deb (--unpack):
trying to overwrite '/usr/share/couchdb/www/favicon.ico', which is also in package couchdb 1.2.0-5
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Selecting previously unselected package couchdb-bin.
Unpacking couchdb-bin (from .../couchdb-bin_1.6.0-0mcr120+1_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/couchdb-bin_1.6.0-0mcr120+1_i386.deb (--unpack):
trying to overwrite '/etc/couchdb/default.ini', which is also in package couchdb 1.2.0-5
Preparing to replace couchdb 1.2.0-5 (using .../couchdb_1.6.0-0mcr120+1_all.deb) ...
[ ok ] Stopping database server: couchdb.
Unpacking replacement couchdb ...
Processing triggers for man-db ...
E: Sub-process /usr/bin/dpkg returned an error code (1)
v3g4n
Post by v3g4n » Tue Mar 15, 2016 8:53 am
I just gave this a try, I first install couchdb from the default repos then tried to upgrade to 1.6 from the testing repos. I actually got a different error then you, but just selected couchdb-bin to be installed and it went through without issues. If this doesn't work for you, you could backup your config file if you have made any changes, purge couchdb and try and install couchdb from the testing repos. And like I said, if you for some reason run into any errors, try and install couchdb-bin instead of couchdb.
Return to “Package Requests/Status - MX-14”
