[Solved]Stucking before starting XFCE
Good afternoon,
yesterday my system ran smoothly but now due to ever reason while booting it stucks and does not get into XFCE.
The only thing what I am seeing is a blinking cursor. Launched console is is throwing
FAIL startpar: service(s) returned failure: plymouth ... failed!
Any advice what needs to be done in order to fix it ?
thanks in advance
thanks in advance
Re: Stucking before starting XFCE
If you have an nvidia GPU see
viewtopic.php?f=97&t=51081
yes I have...ok I will
Ok this worked fine...
thanks for your quick help
have a good one
have a good one
It hasn't fixed it entirely.
Now I get in to XFCE, however, after I type in the credentials XFCE starts again.
any further advice ?
See if you can log in as root. If so, please run MX Tools/Quick System Info, then right-click paste into a reply. (Quick System Info automatically copies the information to the clipboard and formats it properly for the forum so all you have to do is paste it.) Thanks.
System: Host: black Kernel: 4.19.0-5-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
Desktop: Xfce 4.12.3 Distro: MX-18.3_x64 Continuum May 26 2019
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 4801 date: 04/25/2019
CPU: Topology: 8-Core model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen rev: 1
L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 95805
Speed: 1779 MHz min/max: 1550/3000 MHz Core speeds (MHz): 1: 1356 2: 1375 3: 1369
4: 1368 5: 1306 6: 1978 7: 1319 8: 1330 9: 1375 10: 1374 11: 1329 12: 2721 13: 1352
14: 1332 15: 1375 16: 1375
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1080] driver: nvidia v: 390.116 bus ID: 07:00.0
Display: x11 server: X.Org 1.19.2 driver: nvidia
resolution: 1920x1080~60Hz, 1920x1080~60Hz, 2560x1440~60Hz
OpenGL: renderer: GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 390.116
Audio: Device-1: NVIDIA GP104 High Definition Audio driver: snd_hda_intel v: kernel
bus ID: 07:00.1
Device-2: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 09:00.3
Device-3: Kingston type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-1:2
Sound Server: ALSA v: k4.19.0-5-amd64
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: f000 bus ID: 03:00.0
Drives: Local Storage: total: 232.89 GiB used: 51.18 GiB (22.0%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 225.99 GiB used: 51.18 GiB (22.6%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
Sensors: System Temperatures: cpu: 37.1 C mobo: N/A gpu: nvidia temp: 50 C
Fan Speeds (RPM): cpu: 0 gpu: nvidia fan: 19%
1: deb http://ftp.de.debian.org/debian/ stretch-updates main contrib non-free
1: deb http://ftp.de.debian.org/debian/ stretch main contrib non-free
1: deb http://ftp.halifax.rwth-aachen.de/mxlinux/packages/mx/repo/ stretch main non-free
No active apt repos in: /etc/apt/sources.list.d/plexmediaserver.list
Active apt repos in: /etc/apt/sources.list.d/skype-stable.list
1: deb [arch=amd64] https://repo.skype.com/deb stable main
Info: Processes: 296 Uptime: 9m Memory: 15.66 GiB used: 744.8 MiB (4.6%) Init: SysVinit
runlevel: 5 Compilers: gcc: 6.3.0 Shell: bash v: 4.4.12 inxi: 3.0.33
The only thing I can think of to try is when logged in as root, go to /home/YourUserName (whatever your normal logon name is), open a terminal and run
again, replacing "YourUserName" with whatever you actual login name is.
Usually, when you get returned to the login prompt it's either a permissions issue which that command should fix, or it's a free space issue in the /home directory.
chown -R YourUserName:YourUserName *
change the ownership without success!
strange..as root it works. My user does not!
But the failure FAIL startpar: service(s) returned failure: plymouth ... failed! is still there. May be this is related to this issue?
any further idea?
any further idea?
Just as a troubleshooting step, as root and in the menu go to MX Tools/MX Tools, open User Manager, and under Add User Account create a new user then log out and try logging in as that user just to see what happens.
