Well, I did solve the problem., Actually, I didn't use gscan2PDF; I saved the screenshot as a PNG then learned how to
convert '/media/DATA/data/school/current/HIM 208 (ICD-10)/blood alcohol level' blood_alcohol_level.pdf
Okay, if you want me to--done. But that suggests you think I meant that this was a problem I couldn't solve. It isn't: I said I knew perfectly well what to do (make the image a file, then open it), and then I found a second solution by learning the convert command. In which case it would not be clear why I posted this in the bugs/requests sub-forum.
