I know its not quite a distro related problem, but its bugging me
Is there any way i could insert them manually?
[Solved] X11 Keyboard switcher (fbxkb 0.6.2) missing Serbian flag
Re: X11 Keyboard switcher (fbxkb 0.6.2) missing Serbian flag
It is distro related and you should be able to add an rc.png image in the directory /usr/share/fbxkb/images/ using the same 60x40 size as the others. If it works, we can add it to the package. You may need to use a format of " 8-bit/color RGBA, non-interlace" but I'm not certain.
-- Richard Feynman
-- Richard Feynman
This is strange. In /usr/share/fbxkb/images/ there already was the Srebian flag sr.png. I added another copy of it naming it rs.png in case that was the problem. Then I removed switcher from dock, added it again and now there is a flag in the dock, but it is an official version of the flag, not just the simplified one like in the /images folder
http://i.imgur.com/zzzjLVT.png
Not sure what was the problem, but removing from the dock and readding it solved it.
EDIT:
Sorry, my mistake. This is completely different program now, not fbxkb at all
http://i.imgur.com/MysXzzy.png
EDIT:
Maybe you were running fbxkb originally and the flag file was missing but then when you restarted it switched to the other program.
-- Richard Feynman
-- Richard Feynman
I think that is what happened. fbxkb was there by default, when i tried to put it back, there is only one option for keyboard switcher and its that other prog.
EDIT:
I created new user, an deleted demo user (home was copied before deletion) and after the reboot there are both keyboard switcher active, one in side panel and the other in new top panel. Interesting thing is that renaming Serbian flag file to rs.png fixed the original issue. Although official flag should be used instead of simplifed one, i think this is a solution.
http://i.imgur.com/j5ZP2RT.png
EDIT:
- Eadwine Rose
- Administrator
Re: [Solved] X11 Keyboard switcher (fbxkb 0.6.2) missing Serbian flag
Mod note: Please keep the maximum image dimensions into account, 600x600, thanks!
Changed the images to links.
viewtopic.php?f=133&t=48374
I see there is an update for fbxkb, with new images. Thanks! :)
