SOLVED:
How to replicate problem:
Do the following as root user
create a crontabfile with the following entry
@reboot touch /root/crontest.tst
(remember a newline after entry)
Load the crontabfile with
$] crontab crontabfile
Check if it was loaded with
$] crontab -l
If so reboot.
Upon reboot there will be no file in /root called crontest.tst as there should be.
I now tried it on two MX18 installs on two different computers.
On both of them cron doesnt execute @reboot.
I suggest the MX18 developers look at which runlevel cron executes crontab.
This cron bug is as old as 2011 and keeps reappearing.
$ cat /proc/version
Linux version 4.19.0-1-amd64 (stevep@mxlinux.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1)) #1 SMP Debian 4.19.5-2~mx17+1 (2018-12-12)
$ cat /etc/*release*
NAME="MX"
VERSION="18 (Continuum)"
ID="mx"
VERSION_ID="18"
PRETTY_NAME="MX 18 (Continuum)"
ANSI_COLOR="0;34"
HOME_URL="https://mxlinux.org"
BUG_REPORT_URL="https://mxlinux.org"
PRETTY_NAME="MX 18 Continuum"
DISTRIB_ID=MX
DISTRIB_RELEASE=18
DISTRIB_CODENAME=Continuum
DISTRIB_DESCRIPTION="MX 18 Continuum"
PRETTY_NAME="Debian GNU/Linux 9 (stretch)"
NAME="Debian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
Cron do not execute @reboot entries in MX18
- Eadwine Rose
- Administrator
Re: Cron do not execute @reboot entries in MX18
Please post config things like this between code tags. Select all and then click the </> button up top. That keeps things nicely formatted for you :)
Works fine here. Have a look:
Example crontab entry for user "root"
$ sudo crontab -l | grep touch
@reboot /usr/bin/touch /root/touched_by_crontab_4_root
fehlix@mx18kvm:~/Desktop
$ crontab -l | grep touch
@reboot /usr/bin/touch /home/fehlix/touched_by_crontab_4_fehlix
$ fehlix@mx18kvm:~/Desktop
$ sudo ls -l /root/touched_by_crontab_4_root $HOME/touched_by_crontab_4_fehlix
-rw-r--r-- 1 fehlix fehlix 0 Jan 21 17:02 /home/fehlix/touched_by_crontab_4_fehlix
-rw-r--r-- 1 root root 0 Jan 21 17:02 /root/touched_by_crontab_4_root
You cannot rely on some magics that the PATH env-variable is always set properly.
I tried both full path and without path and it fails miserably in both cases.
I have tried it now with 3 MX reinstalls absolutely vanilla.
Cron didnt work 3/3 .
It executed everythng except @reboot.
If you share with us, what you have tried, somebody might find the show stopper.
You might also consider to watch for cron entries within system log,
perhabs this might give you an indication what's the issue with your crontab.
Here are mine on the system with those two example entries:
sudo grep -i cron /var/log/syslog
Jan 22 20:03:44 mx18kvm anacron[2078]: Anacron 2.3 started on 2019-01-22
Jan 22 20:03:44 mx18kvm cron[2123]: (CRON) INFO (pidfile fd = 3)
Jan 22 20:03:44 mx18kvm anacron[2078]: Normal exit (0 jobs run)
Jan 22 20:03:44 mx18kvm cron[2142]: (CRON) STARTUP (fork ok)
Jan 22 20:03:44 mx18kvm cron[2142]: (CRON) INFO (Running @reboot jobs)
Jan 22 20:03:44 mx18kvm CRON[2250]: (root) CMD (/usr/bin/touch /root/touched_by_crontab_4_root)
Jan 22 20:03:44 mx18kvm CRON[2252]: (fehlix) CMD (/usr/bin/touch /home/fehlix/touched_by_crontab_4_fehlix)
Solved it using this.
"https://www.nixcraft.com/t/solved-cron- ... ebian/1858"
anacron was running the same time as cron on a default MX18 installation.
ps -A |grep -i cron
1044 ? 00:00:00 anacron
1051 ? 00:00:00 cron
Happens with Debian Stretch too, but the scary thing is it varies from pc to pc. On some anacron wont show up as daemon and on others it will with same install media and clean install. Anyway, it is all in the link.
If both cron and anacron runs as daemons then @reboot is not executed but all timed * * * * * entries in crontabfile are still executed. Very sneaky.
Its clearly a Debian bug long in the running.
After completely uninstalling anacron on MX18, cron could do its job and all worked great and @reboot commands were executed.
ps -A |grep -i cron
zimbodel, thanks for explaining the solution!
