I have a mute button on my keyboard. When I press it, the sound is unmuted. However, when I press it again to unmute it, the sound stays silent.
The popup info, when I press the mute/unmute button shows an mute icon when I press it one time. And when I press it the second time, it shows me an correct unmute icon (ask you can see in the image). But in pulseaudio you can see, that the mute icon is still pressed and not changed. To unmute, I have to press the button under the G of AusgabeGeräte.
Perhaps the port is responsible, perhaps it only works at the default port? However, that's the headphone port of my computer, can't make it any more standard.
The screenshot depicts the moment when I unmute with the keyboard, but the mute icon is still active in Pulseaudio (it should disappear, when I unmute).
Mute works - Unmute doesn't
- Eadwine Rose
- Administrator
Re: Mute works - Unmute doesn't
Now this works for the main sound (so I don't know about the headphones port and how that works exactly.. may want to wait for someone else to chime in before you try this)
First find out which sink corresponds to the audio output you'd like to control. To list available sinks:
Suppose sink 0 is to be used, to mute/unmute the pulseaudio volume, try in the terminal, then try it again to see if it indeed mutes unmutes:
Works? Good. Go into Keyboard (type keyboard in the menu up top) - application shortcuts.
click Add (bottom left)
Enter the command that works for you in the field, click ok. Click the key you want to bind it with, and that should do the trick.
I don't remember if you need to log out and in though.. it's been a while again that I used this.
pactl list sinks short
pactl set-sink-mute 0 toggle
OH GOSH IT WORKS!!! WOW!!! AWESOME!!!
I had to logout login to make it work. But now it's perfect. Wow!
Thank you very much for your help!
Btw. this is the output of "pactl list sinks short". There is just one sink listed:
$ pactl list sinks short
0 alsa_output.pci-0000_00_1f.3.analog-stereo module-alsa-card.c s16le 2ch 44100Hz RUNNING
- Eadwine Rose
- Administrator
It does??
Oh way cool!!! Glad to help
