MX-17.1: Could not install "libx11-dev" due to upgraded "libxcb1"
app4soft
#1 Post by app4soft »
When I try install "libx11-dev" apt return me next
$ sudo apt-get install libx11-dev
Reading package lists... Done
Building dependency tree
 libx11-dev : Depends: libxcb1-dev but it is not going to be installed
UPD: I found what was wrong: recently upgraded "libxcb1" from 1.12-1 to 1.12-3 prevented install "libx11-dev". When "libxcb1" downgraded all seems work.
But there no propper notification why this issue happen, so need check "libxcb1" and "libx11-dev" in MX repos.
philotux
Re: MX-17.1: Could not install "libx11-dev"
#2 Post by philotux »
This might help:
sudo apt install --fix-broken libx11-dev
If it doesn't, post the output from:
inxi -Sr
for forum members to have an idea about your sources.
Re: MX-17.1: Could not install "libx11-dev" due to upgraded "libxcb1"
#3 Post by Stevo »
libxcb1 1.12-3 is coming from the antiX repo, where it was updated for some unknown reason. But libx11-dev installs fine on MX 17/18, which enables the antiX repo by default, so you must have some issue with the antiX repo.
What does "inxi -r" show?
app4soft
#4 Post by app4soft »
Stevo wrote: Tue Jan 15, 2019 3:26 pm libxcb1 1.12-3 is coming from the antiX repo
Thanks, I already fixed this issue by dwngrading libxcb1 by install MX repos.
antiX repos now disabled (for prevent such issues in the future).
#5 Post by anticapitalista »
Out of interest, why do you need libx11-dev?
So we can perhaps fix the problem
#6 Post by Stevo »
I can't reproduce the issue on standard MX with the antiX repos enabled--libx11-dev installs just fine. The OP had something else going on, which is why I requested "inxi -r" (no response, though).
There's nothing to fix, as far as I can tell.
#7 Post by anticapitalista »
Stevo wrote: Thu Jan 17, 2019 6:31 pm I can't reproduce the issue on standard MX with the antiX repos enabled--libx11-dev installs just fine. The OP had something else going on, which is why I requested "inxi -r" (no response, though).
That's why I want the OP to reply.
OP is always asking for MX packagers to upgrade packages. (and I assume installs them)
Maybe this is why OP has an issue?
app4soft
#8 Post by app4soft »
I installed MX using MX-17.1_November.iso
When I try install all dependency for AzPainter there was issue described in this topic. Not sure why I has "libx11-dev_1.12-3" installed on my system, but I found that I should downgrade it to 1.12-1 for fix issue. Then I decide also dissable antiX repos in Synaptic
Here is "inxi -r" output, but it is current state of repos.
$ inxi -r
Repos:     Active apt repos in: /etc/apt/sources.list
           2: deb http://mxrepo.com/mx/testrepo/ stretch test
           3: deb https://notesalexp.org/debian/stretch/ stretch main
           4: deb http://qgis.org/debian/ stretch main
           No active apt repos in: /etc/apt/sources.list.d/antix.list
           1: deb http://ftp.ua.debian.org/debian/ stretch-updates non-free contrib main
           1: deb http://ftp.ua.debian.org/debian/ stretch main contrib non-free
           2: deb http://security.debian.org/ stretch/updates non-free contrib main
           3: deb http://www.deb-multimedia.org/ stretch main non-free
           4: deb http://deb.debian.org/debian/ stretch-backports main
           No active apt repos in: /etc/apt/sources.list.d/mx.list
#9 Post by Stevo »
I build packages now as much as possible in isolated schroots using pbuilder and sbuild, so don't have to worry about those issues with azpainter, which will build on plain vanilla Stretch, so that's how I do it. Those kind of hassles are a thing of the past with those packaging tricks. :happy:
#10 Post by timkb4cq »
Leaving deb-multimedia enabled is notorious for creating dependency issues. We only include it in our package lists at all (disabled by default) for a few patent encumbered libraries like libdvdcss2
