Timeshift in MX 18?
colin_b
Timeshift in MX 18?
#1 Post by colin_b »
I have seen that have been quite a few problems with MX 17 after recent updates.
I have used Timeshift on my MX 16 for nearly a year now, and it has worked flawlessly in creating system snapshots. I have fortunately not had the need to revert my system, but I know that it is a simple job if it is required.
https://itsfoss.com/backup-restore-linux-timeshift/
Would it be possible to add Timeshift to MX 18?
It would solve a lot of headaches with a minimum of fuss.
Re: Timeshift in MX 18?
#2 Post by Jerry3904 »
Unlikely, but it's in the repos so easy to install:
$ apt policy timeshift
timeshift:
  Installed: (none)
  Candidate: 17.11-1mx17+1
  Version table:
     17.11-1mx17+1 500
        500 http://mirror.umd.edu/mxlinux/antix/stretch stretch/main amd64 Packages
        500 http://mirror.umd.edu/mxlinux/mx/repo stretch/main amd64 Packages
Maybe it can sneak into the Package Installer...
#3 Post by Stevo »
Debian recently added it, too, so we have a backported 18.9 version in the test repo.
manyroads
#4 Post by manyroads »
Hi @stevo.
I installed it on 18rc1 it seems to work. I'll add a usb drive for it to use tomorrow. I'll report any issues.
colin_b
#5 Post by colin_b »
Stevo wrote: Sun Dec 16, 2018 9:26 pm Debian recently added it, too, so we have a backported 18.9 version in the test repo.
I updated to the 18.9 version and I have done a bit of testing.
I set Timeshift to create a backup file after boot-up and left it to its own devices.
Shortly after it was set up an initial backup file was created, this took a few minutes to complete.
I set Timeshift to have 3 backup files, and after reboot the second file was created, but this time it was done in seconds rather than minutes. The older version of Timeshift had a quirk where two backup files were created after a reboot, this does not affect this version. Hurrah! :happy:
A few hours later I downloaded a small update from the update manager and allowed it to install.
I then fired up Timeshift, selected the previous restore point, held my breath, and then selected restore.
When the restore was complete the computer rebooted and I was presented with the desktop upon completion of reboot.
I checked the update manager and found it once again had the updates listed which I had previously installed, so the restore had indeed done its job.
In as nutshell, the updated Timeshift from the test repo does an admirable job.
manyroads
#6 Post by manyroads »
I tried it (Timeshift) and found it slow and less useful (and slower) than grsync....
#7 Post by richb »
manyroads wrote: Mon Dec 17, 2018 10:41 pm I tried it (Timeshift) and found it slow and less useful (and slower) than grsync....
Confused. This post seems to say it is very good.
https://forum.mxlinux.org/viewtopic.php ... 75#p473075
#8 Post by Stevo »
Thanks for testing 18.9! On the basis of it fixing those bugs, we should move it to main.
colin_b
#9 Post by colin_b »
I like simplicity. Timeshift did what I needed a minimal amount of head scratching. grsync looks more suited for advanced users.
The initial backup by Timeshift took a few mins. Subsequent ones only took a few seconds and were non-intrusive, so I don't see this being an issue.
Stevo wrote: Mon Dec 17, 2018 10:51 pm Thanks for testing 18.9! On the basis of it fixing those bugs, we should move it to main.
Hopefully it will be put to good use.
:number1:
dphn
#10 Post by dphn »
have installed timeshift for a while from LMDE3 repo and now I've become an update from MX for that. Fantastic.
