Forum users
--MX-23 release info here
[Solved] OpenGL problem when trying to launch DOTA 2
catalinux
#1 Post by catalinux »
Hi!
whenever I try to open DOTA 2 I get this error:
http://i.imgur.com/Ptsjlxc.png
At first I thought it was maybe because MX needs to update OpenGL in order to work. But the problem isn't going for a month. But when I checked DOTA 2's store page on Steam I saw that I was meeting the minimum requirements. More specific:
  • Graphics: nVidia Geforce 8600/9600GT (Driver v331), AMD HD 2xxx-4xxx (Driver mesa 10.5.9), AMD HD 5xxx+ (Driver mesa 10.5.9 or Catalyst 15.7), Intel HD 3000 (Driver mesa 10.6) -----> these are the minimum requirements for running the game on Linux
  • Card-1: Intel HD Graphics 520 driver: i915 v: kernel
    resolution: 1366x768~60Hz
    OpenGL: renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2)
    v: 4.5 Mesa 13.0.6 -------> this is what I've got
Any solution for this? I'd really not want to go with WINE for this game.
Acer Aspire One D260
Lately got a Lenovo V110-15ISK too
Re: OpenGL problem when trying to launch DOTA 2
#2 Post by timkb4cq »
Well, your setup should support it, but how about running these commands and pasting the output back here to see if your setup shows that it supports it.
run:
glxinfo | grep st3
and see if GL_EXT_texture_compression_s3tc shows up in the list. Also include:
glxinfo | grep OpenGL
#3 Post by Stevo »
S3 texture compression was protected by patents until last September, so Debian Stretch has a lower performance libtxc-dxtn-s2tc package that'll substitute for it, or you can now legally use deb-multimedia's libtxc-dxtn0 which has s3tc.
An alternative is to upgrade to the Mesa 17.3.9 stack in stretch-backports, which also should support it natively: https://www.phoronix.com/scan.php?page= ... sa-Finally
catalinux
#4 Post by catalinux »
Thanks! I installed the libtxc-dxtn-s2tc library since libtxc-dxtn0 asked me to uninstall libtxc-dxtn-s2tc:i386 and even Steam itself (don't know why, but I didn't want to uninstall and reinstall the stuff and maybe lose some data in the process). Looking forward for Mesa 17.3.9 in the main repos in the near future :D
#5 Post by Stevo »
catalinux wrote: Tue Aug 07, 2018 8:25 am Thanks! I installed the libtxc-dxtn-s2tc library since libtxc-dxtn0 asked me to uninstall libtxc-dxtn-s2tc:i386 and even Steam itself (don't know why, but I didn't want to uninstall and reinstall the stuff and maybe lose some data in the process). Looking forward for Mesa 17.3.9 in the main repos in the near future :D
I doubt that we want to force that upgrade onto all users by putting it into main. It's really only needed now for the correct open GL acceleration if you have cutting edge stuff like Intel 8th-gen Coffee Lake graphics. We actually have Mesa 18.0.4 in an experimental branch off of the test repo: http://mxrepo.com/mx/experimental/pool/test/m/mesa/
When we start getting more and more issues with new hardware, as will surely happen, we'll consider moving the experimental packages to the test repo. But we also might begin working on a Buster-based MX 19 instead, since Buster is supposed to be entering a freeze soon for a early 2019 release.
catalinux
#6 Post by catalinux »
There's no rush for it. I don't want a forced update to it either since I know there might be some stability and compatibility issues. What I meant was that I'm patient enough for the future OS releases (either Debian or MX) for Mesa to be refined enough for the stable repos. I didn't mean to rush anything :D
Anyway, DOTA moves great. I only had the issue ofXfce panels overlaping the game window. But as a workaround I made the panels auto-hide and they stay hidden even when getting the cursor near them (weird, but works tho)
