Dark theme tweak [solved]
colin_b
#1 Post by colin_b »
I'm using MX17.1 with a dark theme on a live USB with persistence enabled. When I check the dark theme tweak it works as advertised on Firefox. After a reboot the dark theme tweak checkbox still shows enabled, but when Firefox is used the tweak is no longer applied.
Is this down to running MX on a live USB?
Re: Dark theme tweak
#2 Post by Jerry3904 »
If you're not using persistence, it won't persist, right?
colin_b
#3 Post by colin_b »
Jerry3904 wrote: Thu Jul 12, 2018 9:16 pm If you're not using persistence, it won't persist, right?
I am using persistence (honest).
#4 Post by dolphin_oracle »
are you just launching firefox from the menu? or do you have any custom launchers?
the tweak is designed to be used with "firefox" as the launch screen. or /usr/local/bin/firefox. /usr/bin/firefox will bypass the tweak.
our desktop files use "firefox" as the exec.
Last edited by dolphin_oracle on Thu Jul 12, 2018 9:32 pm, edited 1 time in total.
colin_b
#5 Post by colin_b »
I'm launching it from the whisker menu.
#6 Post by dolphin_oracle »
colin_b wrote: Thu Jul 12, 2018 9:31 pm I'm launching it from the whisker menu.
with the tweak enabled, launch "firefox" from the terminal, and post any output.
also, is adwaita themes present?
this is the entire tweak script (firefox.real is there to help deal with firefox-esr when installed via debian repos).
#!/bin/bash
if [ -a /home/$USER/.config/FirefoxDarkThemeOverride.check ]; then
    if [ -e /usr/bin/firefox.real ]; then
        echo "Dark Theme Override"
        env GTK_THEME=Adwaita /usr/bin/firefox.real "$@"
    else
        env GTK_THEME=Adwaita /usr/bin/firefox "$@"
    fi
else
    else
    fi
fi
colin_b
#7 Post by colin_b »
dolphin_oracle wrote: Thu Jul 12, 2018 9:33 pm with the tweak enabled, launch "firefox" from the terminal, and post any output.
I'm afraid the terminal is foreign to me.
dolphin_oracle wrote: Thu Jul 12, 2018 9:33 pm also, is adwaita themes present?
I've had a look in the window manager and I can't see it.
#8 Post by dolphin_oracle »
colin_b wrote: Thu Jul 12, 2018 9:39 pm
these screen shots will help you with what I ask.
colin_b
#9 Post by colin_b »
My apologies for being a dummy :confused:
I've found the adwaita theme.
I ran FF from the terminal and the problem does not occur. The terminal briefly flashed up something about the dark theme tweak before FF sprang to life.
#10 Post by dolphin_oracle »
ok, now some output for the firefox launcher in the menu.
cat /usr/share/applications/firefox.desktop
cat /home/$USER/.local/share/firefox.desktop
thanks!
