Add Ryzen sensors support to kernel plz!
njskalski
#1 Post by njskalski »
I like MX Linux a lot, it works like a charm on my laptop. But I do have a problem with my desktop - I use Ryzen 1700X with B350 chipset and be-quiet cooling. With Ubuntu the computer is basically noiseless after boot, but with both Debian Stable (with backported 4.15 kernel) and MX Linux the fan runs on 100%, like during boot or in bios. I personally guess it's because these
https://linuxconfig.org/monitor-amd-ryz ... el-modules
are not included in default kernel config. While I could build a kernel myself, I honestly have no time to do it :(.
Would you consider adding it to your build?
Kind Regards
Andrzej J Skalski
github.com/njskalski
Re: Add Ryzen sensors support to kernel plz!
#2 Post by Stevo »
Those modules are included in at least the backported Debian 4.17 kernel and the 4.17 Liquorix kernels, both of which are available in our test repo. I don't know about the antiX kernels also available there...Can you give one of those a try?
