Psensor not recognizing HDD on boot
technwarnersprings
#1 Post by technwarnersprings »
When I boot up or restart my system Psensor wont recognise the HDD thermal sensor. I have to logout and then logon for it to work. This occurs on both of my MX-17 PC's.
KoO
Re: Psensor not recognizing HDD on boot
#2 Post by KoO »
You may need to give hddtemp normal user access
hddtemp with out sudo = chmod u+s /usr/sbin/hddtemp
If that does not work run the below command and answer yes to the first question. This can be a slight security risk .
sudo dpkg-reconfigure hddtemp
technwarnersprings
#3 Post by technwarnersprings »
SOLVED!!! Running hddtemp with out sudo = chmod u+s /usr/sbin/hddtemp resolved the issue.
Gordon Cooper
#4 Post by Gordon Cooper »
Please go back to your original post and Edit it to add Solved in the title.
