MX Tools icons
colin_b
MX Tools icons
#1 Post by colin_b »
Both the live USB kernel updater and live USB maker are lacking icons. Is this intentional?
Re: MX Tools icons
#2 Post by dolphin_oracle »
colin_b wrote: Sat Jun 23, 2018 9:00 pm Both the live USB kernel updater and live USB maker are lacking icons. Is this intentional?
this is probably theme dependent to an extent.
the icon in use is
drive-removable-media-usb
and in our default icon set, as well as many others, its provided. but it looks like it doesn't exist in all sets (adwaita is one example).
colin_b
Re: MX Tools icons
#3 Post by colin_b »
That's a bit of a kicker.
Would it be possible to have a complete icon set which is fixed and doesn't change for the tools?
Re: MX Tools icons
#4 Post by dolphin_oracle »
colin_b wrote: Sat Jun 23, 2018 9:50 pm That's a bit of a kicker.
If you would like an icon to show for the for any theme that is lacking a drive-removable-media-usb icon definition, you can place a symlink to whatever icon you want in /usr/share/pixmaps
for instance
sudo ln -s /usr/share/icons/Adwaita/48x48/devices/drive-removable-media.png /usr/share/pixmaps/drive-removable-media-usb.png
will get you this in any theme that is lacking the drive-removable-media-usb as long as adwaita theme is installed.
Re: MX Tools icons
#5 Post by Adrian »
Can we always count on adwaita to be on the computer? I could set adwaita icon to be the fallback icon (or I could package an icon and make that the fallback, but I prefer if I just link to it rather than adding it to the package).
colin_b
Re: MX Tools icons
#6 Post by colin_b »
Adrian wrote: Sat Jun 23, 2018 10:48 pm I could set adwaita icon to be the fallback icon
Genius idea :number1:
Just out of curiosity, could this be applied system-wide to eliminate missing icons?
Re: MX Tools icons
#7 Post by asqwerth »
I am against this.
I like the fact that the more comprehensive icon sets have designed their own icons for (or have assigned existing icons in their theme to) various mx tools/applications. It will also match the look of the rest of your desktop when you apply a particular icon theme.
Example: the monotone icon set
viewtopic.php?p=440014#p440014
I'm fine with setting a fallback icon theme, for cases where the icon theme in play at the moment does not have an icon assigned to a particular MX app.
I thought in any case that the MX tools had fallback icons in /usr/share/pixmaps already.
colin_b
Re: MX Tools icons
#8 Post by colin_b »
I agree that the fallback option is best. My initial suggestion was simply an idea.
