Gis Weather not loading for some reason, looking for substitute
Eadwine Rose
Re: Gis Weather not loading for some reason
#11 Post by Eadwine Rose »
richb wrote:Eadwine, mine is all messed up as well. I guess I am the purge and reinstall stage.
It should get fixed that way, I have it working and running again. Wait and see after a reboot now of course, but that is for tomorrow ;)
edit: for just now, working peachy. :)
#12 Post by richb »
Mine too.
Eadwine Rose
Re: [solved] Gis Weather not loading for some reason
#13 Post by Eadwine Rose »
Glad to hear that sorts it!
I have turned on the indicator now in the notification area, hopefully when something like this happens again I will be able to right click that and edit the location that way. I have set it to hidden there so I won't see it, but I will have access to it then if I want to.
It's too bad really because the server I had before indicated the rain in MMs for the upcoming days, this one does not appear to have that setting.
#14 Post by richb »
I preferred Accuweather as I could get the weather in Charlotte, NY. It is near Lake Ontario and the temperatures are often different from Rochester, NY because of the Lake. At times between 15 deg to 20 deg cooler. Gismeteo does not have Charlotte, NY. But better than nothing.
Eadwine Rose
#15 Post by Eadwine Rose »
Yes indeed.
Hopefully someone can/will adjust the code... I mean it shouldn't be too hard if it is an http vs https problem.. but I am not getting my hopes up.
Eadwine Rose
#16 Post by Eadwine Rose »
#17 Post by timkb4cq »
I just submitted a bug report on their GitHub. There's been little activity there in the last 2 years but they did change their internal copyright notices to 2018 so the developer will probably see it.
Eadwine Rose
#18 Post by Eadwine Rose »
Fingers crossed!! And thank you :)
Eadwine Rose
#19 Post by Eadwine Rose »
Rich maybe the YR one will work? Gismeteo, compared to my digital outside meter, was always about 5°C off, just now connected with YR and that one states the temp correctly.
#20 Post by richb »
Thanks I will give it a try.
EDIT: Still cannot get my closest location, Charlotte, NY. And Gismeteo appears to be more in line with my digital outdoor thermometer on a first check.
