I have a problem installing touchscreen on HP Touchsmart 300-1220.
Bus 003 Device 002: ID 1926:0006 NextWindow 1950 HID Touchscreen
When i try to install driver from manufacturer it say that there are some missing dependencies that can't be satisfied.
sudo apt-get install '/media/mario/Podaci/Instalacije/Programi/nwfermi-0.6.5.0_amd64.deb'
[судо] лозинка за корисника mario:
Reading package lists... Done
Building dependency tree
Note, selecting 'nwfermi' instead of '/media/mario/Podaci/Instalacije/Programi/nwfermi-0.6.5.0_amd64.deb'
nwfermi : Depends: ia32-libs but it is not installable
Depends: xf86-input-nextwindow but it is not installable
Touchscreen
Re: Touchscreen
that is very likely a package built for either an older ubuntu or an older debian.
is there a newer version available? ia32-libs hasn't been around since debian 7. the other package looks like a ubuntu ppa package as well.
looking at the nwfermi questions page on the launchpad site, I see that a user did "solve" his issue by dropping back to debian wheezy (debian 7). https://answers.launchpad.net/nwfermi/+question/665183
Re: Touchscreen
I can't help you personally with that, but according to this Ubuntu forum link:
https://ubuntuforums.org/showthread.php?t=1645591
A person there used the directions for the Touchsmart 600 to get their Touchsmart 300 working with Linux.
By following these directions: https://www.ebower.com/docs/ubuntu-touc ... html#AEN83
I've searched the web pretty well and that's the best that I could come up with. However, when I did a search in the Synaptic package manager, there's an installable app there for configuring touch-screens automatically. I have no idea if this could work for you, but the name of the app within Synaptic is: x11-touchscreen-calibrator
Here's the actual Synaptic description of that package. Perhaps someoen else knows more about this ... ???
Good luck.The purpose is to calibrate the touchscreen's coordinates automatically.
Install this package and it will run automatically in the background of X
Window System.
