Black screen when coming back from suspend
relarDevi
#1 Post by relarDevi »
I tried deactivating the screensaver, thinking maybe it had something to do with it, but yeah, nothing.
I'm not very knowleagble other than basic Linux stuff, so I would appreciate some help.
System:    Host: me Kernel: 4.15.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
           Distro: MX-17.1_x64 Horizon March 14, 2018
Machine:   Type: Laptop System: Sony product: VPCYB15AB v: C9007Z8D serial: N/A
           Mobo: Sony model: VAIO serial: N/A BIOS: Insyde v: R0160Z7 date: 12/22/2010
Battery:   ID-1: BAT0 charge: 6.3 Wh condition: 6.3/41.0 Wh (15%)
CPU:       Topology: Dual Core model: AMD E-350 bits: 64 type: MCP L2 cache: 512 KiB
           Speed: 1486 MHz min/max: 800/1600 MHz Core speeds (MHz): 1: 1596 2: 1596
Graphics:  Card-1: AMD Wrestler [Radeon HD 6310] driver: radeon v: kernel
           Display: x11 server: X.Org 1.19.2 driver: ati,radeon unloaded: fbdev,modesetting,vesa
           resolution: 1366x768~60Hz
           OpenGL: renderer: Gallium 0.4 on AMD PALM (DRM 2.50.0 / 4.15.0-1-amd64 LLVM 3.9.1)
           v: 3.3 Mesa 13.0.6
Audio:     Card-1: AMD Wrestler HDMI Audio driver: snd_hda_intel
           Card-2: AMD SBx00 Azalia driver: snd_hda_intel
           Card-3: N/A type: USB driver: snd-usb-audio
Network:   Card-1: Qualcomm Atheros AR8131 Gigabit Ethernet driver: atl1c
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 78:84:3c:2b:ea:b7
           Card-2: Qualcomm Atheros AR9285 Wireless Network Adapter driver: ath9k
           IF: wlan0 state: down mac: 72:8f:4c:38:c4:91
Drives:    HDD Total Size: 119.24 GiB used: 6.26 GiB (5.3%)
           ID-1: /dev/sda model: PLEXTOR_PX-128S3 size: 119.24 GiB
Partition: ID-1: / size: 114.87 GiB used: 6.26 GiB (5.5%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 65.0 C mobo: 33.0 C gpu: radeon temp: 67 C
Info:      Processes: 175 Uptime: 7m Memory: 7.40 GiB used: 1.19 GiB (16.1%) Shell: bash
           inxi: 3.0.06
oops
Re: Black screen when coming back from suspend
#2 Post by oops »
Hello,
For information, I have already had this issue, and for me it' was a kernel configuration issue (with modules security option I guess ?). Maybe you can try an other kernel?
relarDevi
#3 Post by relarDevi »
Yeah, no luck. I changed to the 4.9 antix kernel and still happening.
oops
#4 Post by oops »
relarDevi wrote:Yeah, no luck. I changed to the 4.9 antix kernel and still happening.
Yes, no luck ... I hope someone can help you...
relarDevi
#5 Post by relarDevi »
:/, no one ? I would really like to get this working.
Richard
#6 Post by Richard »
After Suspend, I get a black screen with a slow, blinking power button on the T430.
Pressing the power button brings back the screen to where I was before.
Sorry, I have no other experiences to offer for your problem.
Perhaps Google with «your computer name suspend problem»
to see what others with same hardware have seen.
Hibernation is not activated on my MX-17.0 UTD.
#7 Post by richb »
One thing you can try is clicking CTRL-ALT-F1 when you get the blinking cursor. Enter your username and user password, then type startx and see if the desktop appears. If it does hopefully someone will come along and tell you how to avoid this procedure and boot directly into the desktop.
relarDevi
#8 Post by relarDevi »
Thanks, typing startx does brings me back to the desktop.
Would very much like that.
juanjuanjo
#9 Post by juanjuanjo »
I have similar problem with MX 17.1 64Bits, when I press a key to come back from supend, the computer don't screen on and after a few seconds it reboot.
  Host: mx Kernel: 4.15.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
  Type: Desktop Mobo: ASRock model: FM2A85X Extreme4 serial: <root required>
  BIOS: American Megatrends v: P1.70 date: 07/11/2013
  Topology: Quad Core model: AMD A8-6500 APU with Radeon HD Graphics
  bits: 64 type: MCP L2 cache: 2048 KiB
  Speed: 2576 MHz min/max: 1700/3500 MHz Core speeds (MHz): 1: 1829 2: 1999
  3: 2341 4: 2283
  Card-1: AMD Richland [Radeon HD 8570D] driver: radeon v: kernel
  Card-2: NVIDIA GM206 [GeForce GTX 960] driver: nvidia v: 384.111
  Display: x11 server: X.Org 1.19.2 driver: nvidia
  resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce GTX 960/PCIe/SSE2 v: 4.5.0 NVIDIA 384.111
  Card-1: AMD FCH Azalia driver: snd_hda_intel
  Card-2: NVIDIA driver: snd_hda_intel
  Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  driver: r8169
  IF: eth0 state: down mac: bc:5f:f4:85:ed:79
  Card-2: Ralink RT2870/RT3070 Wireless Adapter type: USB driver: rt2800usb
  IF: wlan0 state: up mac: 00:25:22:4c:d7:8b
  HDD Total Size: 6.37 TiB used: 2.44 TiB (38.4%)
  ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
  ID-2: /dev/sdb vendor: Seagate model: ST3500320AS size: 465.76 GiB
  ID-3: /dev/sdc vendor: Toshiba model: DT01ACA300 size: 2.73 TiB
  ID-4: /dev/sdd vendor: Toshiba model: DT01ACA300 size: 2.73 TiB
  ID-1: / size: 33.86 GiB used: 6.51 GiB (19.2%) fs: ext4 dev: /dev/sda7
  ID-2: swap-1 size: 3.03 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
  ID-3: swap-2 size: 5.04 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdd6
  System Temperatures: cpu: 6.1 C mobo: N/A
  GPU: device: nvidia screen: :0.0 temp: 35 C fan: 20% device: radeon
  temp: 3 C
  Processes: 205 Uptime: 3h 43m Memory: 7.70 GiB used: 2.79 GiB (36.3%)
  Shell: bash inxi: 3.0.10
#10 Post by fehlix »
relarDevi wrote: Sat Apr 28, 2018 2:26 am I tried deactivating the screensaver, thinking maybe it had something to do with it, but yeah, nothing.
Well, as I've seen a couple of similar issues recently, and thought I might provide an alternative approach.
But you would need to do something in order to find out, whether it fixes your suspend-issue.
Would you mind to help us to help you by doing the following :happy: :
Copy the below text-code into an new file as follows.
Open from the menu the text editor (the default is featherpad).
Paste the below text-code into the empty editor.
[Desktop Entry]
Version=1.0
# fehlix system suspend desktop icon
# save this to suspend.desktop
Type=Application
Name=Suspend
Comment=System suspend via pm-suspend
Exec=pkexec "/usr/sbin/pm-suspend"
Icon=system-suspend
Path=
Terminal=false
StartupNotify=false
Categories=XFCE;Settings;
Save the file with the name "suspend.desktop" onto your Desktop.
Don't change the filename or at least don't change the file-extension ".desktop"
at the end of the filename.
Now close the text editor.
You will now find a new desktop-starter "Suspend"-icon
on your desktop.
When you now klick on this desktop-icon, you will have two confirmations to accept.
The first confirmation: to make the desktop-starter executable.
After that you get asked to enter the root-password to execute the actual system-suspend command.
Now after you have come back out of suspend-mode let us know whether this worked for you.
If yes, I'll show you how to avoid to enter the root-password!
If not, we might tweak a bit further the option of that command ... :alien: :snail:
So give a try! ... and let us know ... good luck :crossfingers:
:puppy:
