[Solved] LibreOffice 6 problem
dreamer
#1 Post by dreamer »
Hi guys,
I have been diving further into MX-17. I’m amazed how much thought and work went into this OS. The manual is very helpful too. So thank you for doing this.
Now something else: LibreOffice 6. I’m having a few problems with it. Minor problems, but still problems. If I write a Linux path like “/home/user/Downloads” in LO then the words become Italic by default. If I write “-something-” then the word gets crossed out by default.
Maybe someone knows how to fix this in LO 6?
Re: LibreOffice 6 problem
#2 Post by Jerry3904 »
You're right, I never noticed that. A little drop of Google shows that those are the result of AutoCorrect, and where to fix it: Tools > Autocorrect, uncheck "While typing" That also turns off other autocorrect features, so I'd have to hunt around to find the exact place.
dreamer
#3 Post by dreamer »
Jerry3904 wrote:You're right, I never noticed that. A little drop of Google shows that those are the result of AutoCorrect, and where to fix it: Tools > Autocorrect, uncheck "While typing" That also turns off other autocorrect features, so I'd have to hunt around to find the exact place.
OK, thanks. I guess my Google-Fu was off today. Still a pretty bad default setting for LO 6. (Maybe LO wants to be more like MS Office?) :cat:
#4 Post by Jerry3904 »
I totally agree.
Gaer Boy
#5 Post by Gaer Boy »
Tools> AutoCorrect> AutoCorrect Options> Options tab. 4th checkbox down - Automatic *bold*, /italic/, -strikeout- and _underline_.
Pity it's all or nothing, but I will leave it checked. It's less disruptive to my typing than using the Ctrl-B combinations.
Phil
Re: [Solved] LibreOffice 6 problem
#6 Post by Jerry3904 »
BTW: I should have said to Dreamer that I knew from his description that it involved AutoCorrect, and I knew the correct term, so that made a G search much easier.
