Greetings!
The terminal without the menu and scroll bars... is it by design? Or is it a bug?
MX17: xfce4-terminal doesn't have menu and scroll bars [SOLVED]
- LordGiodai
Re: MX17: xfce4-terminal doesn't have menu and scroll bars
It's by design, but you can easily right-click it and enable those in its Preferences.
"When in doubt, right-click it!" (Nobody in particular)
- LordGiodai
Thank you very much!
Re: MX17: xfce4-terminal doesn't have menu and scroll bars [SOLVED]
A little tip. Hold Shift key and press Page-up or Page-down key to scroll. Saves moving over to your mouse/trackpad.LordGiodai wrote:Greetings!
My Computer
MAG X570 TOMAHAWK WIFI Motherboard
Ryzen 5 3600 Six Core CPU
2x 8GB DDR4 2666 Memory Modules
NVidia GeForce RTX 3060Ti Grfx Card
M.2 x1 @500GB HDD x1 @ 2TB
